Author Topic: belts gates vs malossi  (Read 5848 times)
art
Re: belts gates vs malossi
« Reply #15 on: June 05, 2010, 03:33:11 AM »
More air bigger jets!Ha!mine didn't realy come to life untill next rs around 55mph with the next r and jets.Now cranks to about an inch past 50 mark and has more'needle can't go any further,still breaking in will cruise at the 50 mark once there at little over 1/4 throttle.The od. is a bit generious about 3 mph.Take off isn't great(stock ver.)30 to 60+ insane.
art
« Reply #16 on: June 05, 2010, 05:11:22 PM »
Hey cygnus just a thought,I would take a good look at that plug to make sure its burning good little over 50 is about right.If you run a pod type air filter should get 55+ with a main jet around #95 to #105 If you can find them.Good  Luck
