Author Topic: ..20 mm carburetor..  (Read 5769 times)
« on: May 11, 2010, 01:41:31 AM »
...i don't know where to start, really....
..i'll just say that the wait and the worry were worth it all...
..you guys might want one of these....
 :o
peace
Shaka
Re: ..20 mm carburetor..
« Reply #1 on: May 11, 2010, 02:13:30 AM »
That's all we get?!  No pics or nothing?!  ??? >:(
« Reply #2 on: May 11, 2010, 02:32:46 AM »
...i broke my cam th other day....
...but this is one of the best purchases i've ever made for my scoot's performance....
.. i'm jetting at 60 degrees...had to increase the stock 95 jet up to a @ 101.5 jet right off th' bat....
..2 chops got me there...
..it's gonna be a bit lean in th' mornin's 45 degree ride to work, but i do believe i'm in the zone...
..may have to go up 1/2 to one more size....but the increase in hp is already apparent...
..i'm happy.......again...
  :o
« Last Edit: May 11, 2010, 02:38:50 AM by wordslinger »
« Reply #3 on: May 11, 2010, 03:55:25 AM »
Broke your cam? AND your happy? The Carb. I get! ?????????
Shaka
« Reply #4 on: May 11, 2010, 04:03:37 AM »
Dang, what's the deal with the cam?  Darn, 4-strokes again! ;)
Sounds like you''re having fun with the carb!  You'll have to give a full performance update after you get some miles on it!  Some pics too! ;)
sticlistul
  • Sex, Scoot and Rock 'n' Roll
« Reply #5 on: May 11, 2010, 10:01:16 AM »
And tell us about fuell consumption too :D.
« Reply #6 on: May 11, 2010, 10:32:00 AM »
..cam-er-a...lol..i just thot about that...lmao...
« Reply #7 on: May 11, 2010, 10:38:13 AM »
..yeah, it has an adjustable needle....sweeeet...still playin with that...
..gotta buy me a new cam tho....
« Reply #8 on: May 11, 2010, 10:39:37 AM »
..ummm fuel consumption....sucks gas!!...lol..sorry stic, but i probly wasn't getting  45 mpg before the carb...
sticlistul
« Reply #9 on: May 11, 2010, 10:45:55 AM »
f$%k  ... this is like a car ... and you didn't get a new engine or other things ...
« Reply #10 on: May 11, 2010, 04:40:52 PM »
Slinger! You normally give us soo much detailed info. You explain the facts so that even a cave man could do it! Now all we get is "CARB GOOD!"? I'm thinking it is sooo good you don't want to sit around posting...
« Reply #11 on: May 11, 2010, 05:05:07 PM »
...patience grasshopper.....
..twas late last evening when i finally washed up, and I must work today....
..stll not through with the jetting, but i'm in a safe zone...
...carb goood.....
« Reply #12 on: May 12, 2010, 04:28:16 AM »
Conitchieee Waaaaa Mother Fjutcher! Who's your Baby?
« Reply #13 on: May 13, 2010, 01:06:15 AM »
..okay so, here it is...
..this 20 mm carb is th' bomb!! (have i said that already?)
..it has a 5 position needle, with a distinctively different taper than my original carb..
..it's gradual at the bottom, then has a step in th middle, then gradual toward the top..
..the diaphram and slider are beefier, and it has a stronger spring..
..the carb's intake port is vertically oval shaped, as opposed to circular on the original..
..the main jet is TINY in comparison to my original, about half the size...
..came in at .095mm..(waaay lean) and is now at 1.02mm... (spot-on)..
..i'm at 3 rotations on the idle screw mix, and in the middle notch of the needle...
..installation was pretty much plug-n-play...
..my scoot is now quicker off the line...noticeably!!..
..which is no small feat, as a dress out around 225 lbs..
..maintained flat land speed is still variable according to the wind,(not nearly as sensitive as before tho) and edges closer toward 50 mph than before..which is my ultimate goal...in a draft, i have no problem keeping up with 45 mph traffic now...which is awesome..
..i've consistently topped out downhill at 95 kmh, with or against the wind, which i couldn't do without the blown air induction on the original carb..
..i am at the limits of my cvt's capabilities...need the over-range variator for any more top end speed...
peace
Shaka
« Reply #14 on: May 13, 2010, 01:13:33 AM »
Sounds like a great upgrade Slinger!
Very descriptive explanation of it also!
So what's next?  The BBK, over-range, reduction gears? ;) ;D
