Author Topic: ..20 mm carburetor..  (Read 5764 times)
Re: ..20 mm carburetor..
« Reply #15 on: May 13, 2010, 01:29:55 AM »
...no bbk until something breaks...
..next step is the variator, without a doubt..i need a new one, and i might as well go bigger...
..i'm still mot sure about the gears, as i don't want to lose bottom end take-off speed...
..wondering if i could turn enough rpms to make gears effective without a bbk...
Shaka
« Reply #16 on: May 13, 2010, 01:42:17 AM »
With the bigger carb and free-flowing exhaust you might be able to turn the gears.  It's all in the cvt tuning!  Might be worth a try
« Reply #17 on: May 13, 2010, 01:44:58 AM »
..true, and even if it didn't, i'd be set for when i do go with a bbk...
..imma get me the bigger variator...might order it tomorrow....
..seems such a waste of capabilities for that to be my limiting factor....
« Reply #18 on: May 13, 2010, 01:47:11 AM »
...btw, thanx zombie, for turning me onto that carb...
« Reply #19 on: May 13, 2010, 01:55:27 AM »
..another btw, it turns out that this is a CVK brand carb...
..haven't googled them yet, so anybody had any experience with one?
peace
« Reply #20 on: May 13, 2010, 01:56:49 AM »
No doubt my Brother! That overrange var will give you the same effect as going w/ a gear set only you will lose nothing on the bottom. It will give you a few more mph on top.
« Reply #21 on: May 13, 2010, 02:04:12 AM »
KEIHIN CVK carb - testing vac. slide function   It's a keihin Cvk is the model
« Reply #22 on: May 13, 2010, 02:15:59 AM »
...wwwwowwww....that's f*kng awesome....that explains a LOT!!!....
« Reply #23 on: May 13, 2010, 02:47:50 AM »
..i'm only looking for a few... ;D
..when i bought this ride, it would do 37mph..at BEST downhill with a wind....
« Last Edit: May 13, 2010, 02:49:25 AM by wordslinger »
« Reply #24 on: May 13, 2010, 02:59:35 AM »
Every reliable mph is a blessing.
« Reply #25 on: May 13, 2010, 03:02:09 AM »
.."reliable" being the key....i'm in it for th' long run...
« Reply #26 on: May 26, 2010, 11:53:34 PM »
...so, i decided to try the 5.5 gram rollers with the bigger carb....
..not too bad...
..i think i could tune the needle to increase take-off speeds, and i really felt the torque difference at..and just off WOT...
..tomorrow is another day...
« Reply #27 on: May 27, 2010, 12:04:31 AM »
That's where you want to feel it. Bottom end torque is good, but feeling it at the top is best!
« Reply #28 on: May 27, 2010, 12:07:10 AM »
..it was an awakening brother....
« Reply #29 on: May 27, 2010, 12:52:30 AM »
...yeah, so i'm able to generate a bit more horsepower, but if i can't get a greater ratio between the drive and the  driven pulley's, then it's all in vain...
..a belt can only ride so high on the drive pulley...
..a few engine rpms and a bit of increase in torque doesn't matter if you can't put it to the pavement...
