Author Topic: People 50cc 2T - 2008  (Read 1823 times)
LCG
« on: May 11, 2010, 05:44:44 AM »
I have an 08 People 50cc 2t and I'm finding out a few things that are different than what I've read about older models:
- They do not have rev limited CDI's
- The speedos are overstated by 5 mph up to 40 (which is really 35) and when I hit 50mph on the speedo, my GPS read 39.8 mph.
- It get's to the real 35 (40 on the speedo), without issue. The reamaing 5 mph takes a lot of time and effort...if ever due to head wind or incline.
- With a derestricted boss drive, I can only hit 39.8 mph in a full tuck, with a 5mph tail wind, after traveling WOT for about 1 mile.
- When on the center stand, the engine rev's much higher than when driving at top speed. However, it never cuts out or sputters.
So, I'm looking for a way to get at least 5+ mph without a big bore kit with pipe/carb combo.
My variator weights are 8 grams. I have stock clutch springs (both large and small). Any words of wisdom would be appreciated.
Re: People 50cc 2T - 2008
« Reply #1 on: May 11, 2010, 06:23:20 AM »
They do not have rev limited CDI's   Depends on where it is marketed for. You can open the air box w/ some holes. keep your tires at full pressure, 6gr. rollers.
« Reply #2 on: May 13, 2010, 11:21:38 PM »
..yeah, post a pic of your cdi, or call out the colors of the wires connected to it..
..is your variator de-restricted?..if not, then that'll get you a few mph, and to me, it sounds like you're just up against the scoots restrictions..
