Did you miss your
activation email
Scooters - 50cc
oil catch can?
3
4
Topic: oil catch can? (Read 7732 times)
Dark13
Full Member
oil catch can?
May 13, 2010, 11:05:12 PM »
http://www.monstergy6.com/product_catch_can.htm
what is the point of this?
and do i really need it?
proud owner of a 2009 kymco agility 50
undead primate
Re: oil catch can?
May 13, 2010, 11:23:26 PM »
..wtf is that....
..reckon i don't need one...
undead primate
Re: oil catch can?
May 13, 2010, 11:24:49 PM »
..hey dark, how th' hells you runnin'?
Dark13
Full Member
Re: oil catch can?
Reply #3 on:
May 14, 2010, 12:07:54 AM »
well i have time to install the new jet and the new filter but.......
i was wondering one thing what is the small hose on the back of the air box that leads to the motor
what is it for and what do i do with it?
undead primate
Re: oil catch can?
Reply #4 on:
May 14, 2010, 12:10:34 AM »
...leave that open, just double it back towards the front of the engine and secure it so it don't flop around...
..it's the valve cover vent...
Dark13
Full Member
Re: oil catch can?
Reply #5 on:
May 14, 2010, 12:12:06 AM »
so i dont have to filter it any?
and should i have it angled a certain way?
undead primate
Re: oil catch can?
Reply #6 on:
May 14, 2010, 12:23:44 AM »
...naah...all that hose does is, vent the slightly positive air pressure from your valve cover...
..the pressure is created by heat, and the introduction of oil into the cam / valve area of your engine..
..basiclly it keeps your scoot from blowing the valve cover's rubber seal...
..just take it loose from the valve cover a cpl times a year, and blow thru it...
..and wipe around the open end of the tube from time to time just to keep everything nice and clean...
Last Edit: May 14, 2010, 12:29:42 AM by wordslinger
You never know do ya!
Close enough to get the idea!
Re: oil catch can?
Reply #7 on:
May 14, 2010, 12:34:48 AM »
Just a gimmick! You can add a real oil can http://www.amazon.com/CCAs-PCV-Oil-Catch-Can/dp/B002P4TIJS The idea is to put this in series from the engine crank case vent, and into the air box. It will keep the air box clean, and allows any oil vapor to condense. The valve on the bottom is for draining any water vapor that condenses. No need for all this on a street scooter tho!
undead primate
Re: oil catch can?
Reply #8 on:
May 14, 2010, 12:35:34 AM »
...who would buy that??
Re: oil catch can?
Reply #9 on:
May 14, 2010, 12:38:02 AM »
Mostly for pro race set-ups w/ lots of blow by from high compression engines. Airplanes use them as well.
undead primate
Re: oil catch can?
Reply #10 on:
May 14, 2010, 12:39:36 AM »
...i reckon the stock airbox setup kinda did the same thing, on a smaller scale...
Dark13
Full Member
Re: oil catch can?
Reply #11 on:
May 14, 2010, 12:56:09 AM »
so what jets are/were all of you running with the stock motor and free flow?
undead primate
Re: oil catch can?
Reply #12 on:
May 14, 2010, 01:01:40 AM »
..i would say, but it's gonna be bigger than most, so......
..i will say that every scoot is different from the others...
...i would suggest starting at 84-86-88, or so, and do plug chops to verify what you have...
Dark13
Full Member
Re: oil catch can?
Reply #13 on:
May 14, 2010, 01:05:06 AM »
well i am just curious because i would think that it being a machine everything would be down to a science
undead primate
Re: oil catch can?
Reply #14 on:
May 14, 2010, 01:09:33 AM »
..that's fundamentally true...
..the science involved, is tuning.... to what
your
scoot needs for optimum performance...
..unfortunately, there is no "magic formula"...
Last Edit: May 14, 2010, 01:12:09 AM by wordslinger
Back
