The oil pump is somewhere plugged into the crankcase. You should be able to follow your oil line from the carb to it. There will be a splitter in the throttle cable. One cable goes to the carb, the other to the oil pump. You will want to somehow hold the oil pump lever all the way open, ie. zip-tie. This will pump the maximum amount of oil to the carb all the time, even at idle.
