Did you miss your
activation email
Scooters - 50cc
Help a noobie out! Upgrade Questions...
Pages:
8
9
10
11
13
Topic: Help a noobie out! Upgrade Questions... (Read 19460 times)
shubonker
Sr. Member
Re: Help a noobie out! Upgrade Questions...
Reply #120 on:
May 25, 2010, 01:02:09 AM »
I just changed my motor oil at 100km. A bit early but o well. Says there is suppose to be some kind of filter? But i don't see it on either end...
my heralding adventure motorcycle blog
undead primate
Reply #121 on:
May 25, 2010, 01:04:43 AM »
..the only filter on the A50 is a screen that drops down from where you remove the hex-plug....
..it has a rubber seal on top of it...when you remove the drain plug, the screen comes out of the crankcase next....
You never know do ya!
Close enough to get the idea!
Reply #122 on:
May 25, 2010, 01:05:17 AM »
You'll be just fine. I watched Water World last nite!
shubonker
Sr. Member
Reply #123 on:
May 25, 2010, 01:08:41 AM »
Crap... i didn't notice any kind of screen. Is it flat? Also, would i be ok without it?
undead primate
Reply #124 on:
May 25, 2010, 01:11:05 AM »
...welllll.... it needs to be there....
..chances are, that it stuck to the crankcase....and it's still there...
..you got a copy of the service manual, shubonker??
shubonker
Sr. Member
Reply #125 on:
May 25, 2010, 01:13:21 AM »
Yep. I'll go fish in the bucket that i drained everything in, and see if its in there. If not, i'll just assume its in the crankcase. *crosses fingers*
undead primate
Reply #126 on:
May 25, 2010, 01:17:04 AM »
...if you didn't see it fall out when you were draining your oil, it's most likely still up in there...
Reply #127 on:
May 25, 2010, 01:21:57 AM »
Or it Never was~
undead primate
Reply #128 on:
May 25, 2010, 01:22:59 AM »
Or it Never was~
..yeah...or what he said...lmao...hope not tho...lol..
undead primate
Reply #129 on:
May 25, 2010, 01:25:14 AM »
...shu, did you see if there's anything printed on the top of your carb??
Last Edit: May 25, 2010, 01:27:08 AM by wordslinger
shubonker
Sr. Member
Reply #130 on:
May 25, 2010, 01:35:03 AM »
Oh ya, forgot to check. I'll go look when i search for the mysterious filter in a lil bit.
undead primate
Reply #131 on:
May 25, 2010, 01:38:13 AM »
...the mysterious disappearing screen.....
..i found parts of a small spider in mine once...
..reckon i mighta oughtta have wiped that funnel out a bit..........
Reply #132 on:
May 25, 2010, 01:40:06 AM »
The Treasure Of The Sierra Madre
undead primate
Reply #133 on:
May 25, 2010, 01:41:30 AM »
..th' lil buggers (british) will crawl right up in there...
Reply #134 on:
May 25, 2010, 01:44:08 AM »
That's why we have a Lyme~ologist. DUH!
Back
