Hey guys, Sorry it's been awhile! There are "stoppers" or "limiters" on top of the reeds. They cannot fail. If you have something wrong there it is generally a crack on one of the reeds. I'm not sure what you mean by "fuel pump" on the zx there is none. One quick test for the reeds can be done with a vacuum cleaner that has a blower output. Something like a shop vac. Remove the spark plug, and set the piston to bottom dead center. Make an adapter that will blow air into the spark plug hole. Using a bungee to hold the throttle wide open you will feel air blowing out of the carb IF the reeds are cracked. If the reeds are good there will be no air flow. give it a try, and post what you get>
