I dont like bursting bubbles Mud, I would replace the clutch. A wobble will stress the shaft to the point of fatigue. Re-check to be sure it is the bell, and not the shaft. Also check your gear oil. You will get loads of dust in the cvt but it shouldn't be "greasy" A can of Carb Clean/Brake Clean will get it all out for you. I would run it for a few days, and open it back up to check the transmission seal. (behind the clutch). Also there is no way to tell who's springs those are. Art is right about the 125 stroker. That was my first option for this scoot. The Dio stroker kit is awesome on a dio tho, and kind of a death trap on the flimsy zx frame. I settled for 60+mph vs 80mph
