Author Topic: hello im new to kymco  (Read 20709 times)
thebatman
Re: hello im new to kymco
« Reply #75 on: June 17, 2010, 01:12:09 AM »
THAT'S RIGHT!!.... I DID HEAR YOU!!!...IMMA WATCHING YOU!!..ROFLMFAO....
"THE BAT"MAN...
Says:
« Reply #76 on: June 17, 2010, 01:16:49 AM »
AAAarrrrgggggg! You are not him, but I think you might be related to each other. Just kidding Bro! I wouldn't want the batman mad at me.
thebatman
« Reply #77 on: June 17, 2010, 01:34:30 AM »
it's all good man...lmao i know i've been a pain in several asses around here, not just yours..thankfully you all still answer..,..
"THE BAT"MAN...
Says:
« Reply #78 on: June 17, 2010, 05:01:25 AM »
Dude SERIOUS? No-one is a pain here! It's all good. The forum was put here for everyone to share, and enjoy. (except that one fk) There's always gotta be one, even if he is made up...... Tag your it~ No tag backs...
mudfreek
« Reply #79 on: June 17, 2010, 10:38:37 AM »
lol so what kinda plugs are the best for performance  and is there any way to keep the oil form building up on the outside of the pipe?
ehh brakes are for sissies
thebatman
« Reply #80 on: June 17, 2010, 11:19:18 AM »
the ngk br8hsa is the plug for the zx, one i use, good plugs.. you can try the br9 plug since you have a kit, after you get her dailed all the way in, iridium plugs(bout 12-15$, y u dial it in first)...   what pipe are you running???.i am running the next r....lmao  nope!! have to clean mine every few days just to keep it nice and chrome.  you will have the oil residue, i know it sux buuut
"THE BAT"MAN...
Says:
« Reply #81 on: June 17, 2010, 11:08:41 PM »
I am using a bp 7-8 hs. My head is milled .5mm so I needed a shorter electrode
mudfreek
« Reply #82 on: June 18, 2010, 01:17:06 AM »
im using a techigas pipe in chrome but unfortunatly the scoot died today it will start spit and spuder but as soon as i let off the gas it dies and wont start back up had to leave it at work  :'( :'( :'( other than the cdi havin isses what other main problems do the zx's have
thebatman
« Reply #83 on: June 18, 2010, 01:28:14 AM »
i had a few issues in the begining(some because of me too), i have 18,100km on her now,(been riding the sh** out of her,lmao,also live in COUNTRY), no problems here,(well, i lied, my one mirror flops,wore out i guess..lol)...of course have changed piston,rings.   did you check the cdi?? are you sure thats it??
"THE BAT"MAN...
Says:
mudfreek
« Reply #84 on: June 18, 2010, 02:20:45 AM »
well im not shure exacly if its the cdi thats whay i asked if there where other electrical issues that are comon with the zx's bike spuddered and backfired 2 nights ago i had a coil and boot one of my old 4 stroke scoots and it seemed to corect the problem i went to work 2dat and then to lunch bike ran awsome when i get ready to drive home it spudderd and backfired and when i let it rev down to an idle it just stalled out and died i then tried and tried for over 2 hrs pum is working fine pulled exhaust off to see if it would start and still no fire but i get great spark fuel is my next thing to look at what about the genorators do they go bad often ? im drawing blanks here
Shaka
« Reply #85 on: June 18, 2010, 03:42:59 AM »
If you are running an aluminum cylinder you will want a 9-8 temp plug, cast iron 7-8.  I'm currently running a 9 with my Airsal kit.
« Reply #86 on: June 18, 2010, 07:08:08 AM »
Does it start right back up when it is COLD? That is generally what a bad cdi/stator will do. The 4t coil you used will not work for too long either. They are not made for the high rpm's of a 2t. Ebay is full of high performance coils for under 25 bucks delivered. Provo scooter is where I got mine. $19.99 delivered. It sounds like you have developed a vacuum leak from what you described tho... Backfire, and sputtering usually shows a lean condition. Try pulling the carb, and give it a good clean up. you may find something loose or cracked, or otherwise out of wack while you are doing that. "discombobulated"
sidthesloth
  • Kymco ZX50
« Reply #87 on: June 18, 2010, 11:14:09 AM »
As zombie said about something being cracked, I found cracks in my carb. insulator. I sealed it by rubbing RTV silicone into the cracks and that held until I got the new one, (10 months), our parts supply is a little "discombobulated" 'round these parts. :D
mudfreek
« Reply #88 on: June 18, 2010, 11:41:02 PM »
ok guys im pretty shure its the cdi and it had a vac leak this mornin i got workin on it and changed the vac line it started up great even with the electric start no issues as soon as i put the covers back on and let it sit in the sun back to no start so i tried a trick that i learned from workin on honda cars i put ice directly on the cdi after a few mins it started right up i let it idle for about 10 15 mins and it started runnin like cucka poo wont rev barely idled so i have determined its the cdi  what yall think am i wrong or should i look else where
« Reply #89 on: June 19, 2010, 06:26:18 AM »
That is exactly the way 90% of the zx cdi failures act. I had three in less than a year do that.
