The shop should have put in a NEW air filter, and spark plug. Have you CHANGED the plug yet? If that does not fix it I would get into the carb. If the jets are getting cloged it will lean out the fuel mix, and do more damage than you would think. Sea foam is a good start to TRY to clear it, and a few tanks of fresh fuel/Sea foam will tell.
