...yeah, outter diameter...the clamps will seat between the teeth of the flywheel at roughly 180 degrees ...brace the handle's releasing lever against your boot, or a block of wood, and loosen the nut with a socket and ratchet...
..the first time you loosen this nut, is going to be difficult...it's seated tightly....
