Author Topic: Impact wrench for boss  (Read 5828 times)
briandrum
Re: Impact wrench for boss
« Reply #15 on: May 25, 2010, 10:20:15 PM »
So.....here I am at the inn laws..once again w/ the cover off.  I'm not a stupid person, but for the life of me, I cannot figure out how to, or where to put the vise grip to get proper leverage!  Someone just call me already!  860-575-8244....PLEASE!  ;D
Ran into a rain storm....I ducked back into a bar door.....
briandrum
« Reply #16 on: May 25, 2010, 10:26:00 PM »
OR, send me a photo of where I should clamp down this bitch so I cann change this thing once and for all!  :)
shubonker
    • a motorcycle blog
« Reply #17 on: May 25, 2010, 10:29:33 PM »
briandrum
« Reply #18 on: May 25, 2010, 10:33:11 PM »
Nope! :-\  just a regular pair of ole vise grips...a beer, a smoke and pissed off brain....
« Reply #19 on: May 25, 2010, 10:35:41 PM »
..those are the ones!!
..you might have to remove the adjusting screw to get them open wide enough...
..clamp them on the outside of the teeth of the flywheel, AT ITS WIDEST POINT... with the releasing lever facing down and toward the right...
..wedge the lever / handle against your foot, and pull up, counter-clockwise on the ratchet handle...
..PULL REALLY HARD!!!!
« Reply #20 on: May 25, 2010, 10:38:00 PM »
..dammit.....have a beer my brother....
briandrum
« Reply #21 on: May 25, 2010, 10:43:27 PM »
Not sure what type of 'regular' vise grips you have slinger,  ;D, but mine won't open THAT wide.....are you saying to open them up and basically clamp right on the teeth themselves?  Damnit, I wish I had done this before or that the impact wrench I had worked!  This is beyond frustrating!
« Reply #22 on: May 25, 2010, 10:44:43 PM »
..i have the ones in the pic below....
..i was quoting you!!..lol..
..not very "regular"...lol..
« Reply #23 on: May 25, 2010, 10:50:51 PM »
...on the outside edge of the thing with all the teeth...lmao..
..with the vise-grip clamps...as wide as they will go....
 ;D
..click on pic for larger view...
shubonker
    • a motorcycle blog
« Reply #24 on: May 25, 2010, 11:24:11 PM »
Hey slinger, what do you use to hold the clutch to remove that clutch bolt?
« Reply #25 on: May 25, 2010, 11:48:54 PM »
..i got a piece of 1" X 1/4" cold roll steel bar at work...about 18" long...
..drilled a cpl of 3/8" holes that match the spacing between the first and third holes in the clutch bell...
..fastened a cpl of short bolts through the holes with nuts, so they wouldn't move around...
..just insert the bolts into two holes in the clutch bell, prop the bar against the ground, and remove the nut...
..some others have made a tool that's very similar to the tool they make for this purpose...there are pics somewhere around here..lol..
..I also made a tool to help disassemble the clutch, once it's been removed...
« Reply #26 on: May 25, 2010, 11:51:40 PM »
..here's one of those pics...
« Reply #27 on: May 25, 2010, 11:58:21 PM »
...here's the clutch compressor tool i made...
shubonker
    • a motorcycle blog
« Reply #28 on: May 26, 2010, 12:20:32 AM »
Idk where to get metal like that :(
« Reply #29 on: May 26, 2010, 12:23:28 AM »
..any local metal fabrication shop could hook you up...
..they'd probably give you the pieces....and for a small small fee, they might even make them for you...
..just a few dollars in materials...steel is cheap...
