Author Topic: ..please help!!..  (Read 3158 times)
..please help!!..
« on: May 26, 2010, 08:53:30 PM »
...i'm trying to find a larger diameter variator for my A50...
..my Malossi multivar is roughly 3.52 inches, or 90mm...
..i notice that the variator for the S9 is the same as the cobra, people50, dink and a few others..all two-strokes..
..what i would ask is, that the next time any of you guys are in your cvt, could you measure the outer diameter of your variator and the diameters of your output shaft and drive boss??
..i think that these two stroke variators might have larger diameter variators, and if the shaft size is the same as mine, i could make it work for me...
peace
Shaka
Re: ..please help!!..
« Reply #1 on: May 27, 2010, 04:42:56 AM »
My ZX50 oem variator is 88mm across the face.
The drive boss is 20mm OD, 14mm ID, 38.5mm length.
sidthesloth
  • Kymco ZX50
« Reply #2 on: May 27, 2010, 07:44:05 AM »
M Dr. Pulley sliders (6 gram) turned up today, so when I put them in I will measure my variator. The boss wouldn't really matter, you could get it machined to suit if needed. :)
« Reply #3 on: May 27, 2010, 09:46:36 AM »
..the boss would matter if it's I.D is too big for my scoot's output shaft...
sidthesloth
  • Kymco ZX50
« Reply #4 on: May 27, 2010, 09:52:34 AM »
If you use your boss you could machine it down to suit if it is a larger o.d.
« Reply #5 on: May 27, 2010, 09:54:40 AM »
..not if it's O.D. is smaller than the I.D. of the variator...
sidthesloth
  • Kymco ZX50
« Reply #6 on: May 27, 2010, 09:57:58 AM »
Could always get one made, may be worth the one off cost.
sidthesloth
  • Kymco ZX50
« Reply #7 on: May 30, 2010, 03:48:57 AM »
Forgot to measure it yesterday so pulled it apart again and measured it this morning
Variator O.D 89mm
COLLAR
Length:- 36.9mm
O.D.   :- 20mm
I.D.    :- 14mm
« Reply #8 on: May 30, 2010, 03:52:53 AM »
...dude...........thanx..............
« Reply #9 on: May 30, 2010, 04:05:23 AM »
Variator O.D 89mm  MALOSSI MEASURED AT 90MM
COLLAR
Length:- 36.9mm.....MALOSSI @ 37.4
O.D.   :- 20mm.......mALOSSI @ 19.95
I.D.    :- 14mm......MALOSSI @ 13.8
..STOCK a50 COLLAR LENGTH IS 38.5mm
« Reply #10 on: May 31, 2010, 04:17:21 AM »
Hey Slinger I lost track of the post w/ the belt size. I have compared the oem #'s and they are different. The searching I have done give me #'s taht are every where from 739-752mm for the same belt. That may be why so many others have blown belts that are claimed to be correct. I had the same trouble when i installed the Malossi Var before doing the clutch. I would suggest getting the full kit deal, and the belt that matches. It seems the most reliable way. I will look more tomorrow
