Did you miss your
activation email
Scooters - 50cc
..95 mm variator..
3
Topic: ..95 mm variator.. (Read 6132 times)
undead primate
..95 mm variator..
May 27, 2010, 09:16:13 PM »
...so, this Polini is 95mm...just 5mm greater than my Malossi...is it worth a try??
..how much difference could 5mm make....
Shaka
Re: ..95 mm variator..
May 28, 2010, 04:50:37 AM »
Wow, notice the notches at the end of the ramps? That is exactly what I tried doing! I bet 5mm will make a noticeable difference. I would think at least a few extra mph's! The other thing to consider is you will need a slightly longer belt to utilize the extra height.
You never know do ya!
Close enough to get the idea!
May 28, 2010, 05:28:07 AM »
my thought is the same. Take 5mm off your belt and the difference is huge. Try wrapping 5mm of electric tape around your Malossi, and be sure it will fit first. I think that, and an orer-range clutch will get you close to 60mph.
undead primate
Reply #3 on:
May 28, 2010, 11:13:23 AM »
..i have a good half inch of clearance around my variator...i was thinking much bigger....
Reply #4 on:
May 28, 2010, 08:21:48 PM »
http://www.exriders.com/archive/topic/380672-1.html
Some of this gets juvinal, but there are some good points made here. It's gonna be more involved than jetting was to get the set-up correct. There are a few good ideas for sourcing the parts in here too. My comp. has still got a few bugs to work out so I can't surf around too much yet, BUT I WILL KEEP TRYING FOR YOU BRO...
undead primate
Reply #5 on:
May 28, 2010, 10:04:02 PM »
..josh, over at scooterinvasion forum spoke of this set...
...this look intriguing....
..it has a 1000 torque spring tho....
..two slightly different versions..
..less than $200.00
Last Edit: May 28, 2010, 10:14:11 PM by wordslinger
Reply #6 on:
May 29, 2010, 02:12:34 AM »
The second (complete) set looks intriguing...
undead primate
Reply #7 on:
May 29, 2010, 02:15:23 AM »
...what you see thats not right with the first pic set??..
..it's 20 bucks more, but the clutch bell has that cool "N" cut into it...
Reply #8 on:
May 29, 2010, 02:19:38 AM »
I think the "N" is the frame shape they based the Eiffel Tower on. I could be wrong!
undead primate
Reply #9 on:
May 29, 2010, 02:23:50 AM »
..i reckon ncy is a respectable brand??
...it just seem like probably a good upgrade given that i have so many miles on my scoot..and ALL it's OEM parts..
Reply #10 on:
May 29, 2010, 02:56:23 AM »
No Doubt! 200.00 for a full cvt is outstanding. I wish you could see it all first. Ps. I blew my belt today riding wheelies for my friends kids. It's not ALL bullet proof~
undead primate
Reply #11 on:
May 29, 2010, 03:11:29 AM »
...you suck...with your wheelies and schtuff...
..ncy...good??
undead primate
Reply #12 on:
May 29, 2010, 03:12:42 AM »
http://www.scooterworks.com/NCY_GY6_-_50cc_Performance_Tra_P9860C586.cfm
undead primate
Reply #13 on:
May 29, 2010, 03:56:12 AM »
..the other one...
http://www.scootertronics.com/gy6ncytrco.html
shubonker
Sr. Member
Reply #14 on:
May 29, 2010, 02:31:00 PM »
Theyre both from the same taiwanese company, only scooterworks is cheaper. I'd go with them. I just checked on NCY's website, scooterworks seems to be a direct US distributor for NCY, so i guess that's why they're chaeper.
Last Edit: May 29, 2010, 02:34:08 PM by shubonker
my heralding adventure motorcycle blog
Back
