Author Topic: ..95 mm variator..  (Read 6133 times)
Re: ..95 mm variator..
« Reply #15 on: May 30, 2010, 02:26:43 AM »
You can surely get either kit from scooter works. Remember Tronics re orders when you do. Works may have them in stock.
« Reply #16 on: May 31, 2010, 01:30:27 AM »
...there should be a formula for determining what belt length would be needed if your variator is 5mm greater in diameter...
« Reply #17 on: May 31, 2010, 01:40:09 AM »
Measure the circumference of each one, and add the difference to the belt length.   I think...http://www.csgnetwork.com/pulleybeltcalc.html    determine belt length from pulley size   Just google that, and you will find it
« Reply #18 on: May 31, 2010, 01:56:21 AM »
The size is: 748 18 28
...you said in another post..
...provoscooter says Malossi Kevlar Dimensions 743 X 18 X 30
..i'm assuming the 700 number is the circumference....
« Reply #19 on: May 31, 2010, 02:12:00 AM »
I believe that is right. 700's=length    18=width    28=notch type. Gates also makes a kevlar belt, and you can direct order one at any given size. I'm trying this one as a spare as Malossi usa is out of stock on mine.   http://www.gates.com/    http://www.powersportsmax.com/product_info.php/products_id/14054
« Reply #20 on: May 31, 2010, 02:15:42 AM »
..enviromoto....
..who is right??
     669-18 30
« Reply #21 on: May 31, 2010, 02:17:35 AM »
  669-18 30?   What is that #
« Reply #22 on: May 31, 2010, 02:22:37 AM »
...what enviromoto had for the a50 belt size...
« Reply #23 on: May 31, 2010, 02:41:36 AM »
3000...you got me....
 ;D
« Reply #24 on: May 31, 2010, 04:23:14 AM »
Hey Slinger I lost track of the post w/ the belt size. I have compared the oem #'s and they are different. The searching I have done give me #'s taht are every where from 739-752mm for the same belt. That may be why so many others have blown belts that are claimed to be correct. I had the same trouble when i installed the Malossi Var before doing the clutch. I would suggest getting the full kit deal, and the belt that matches. It seems the most reliable way. I will look more tomorrow
..you're probably right, but who really knows what belt is correct...
..i'm beginning to wonder....
« Reply #25 on: May 31, 2010, 04:32:12 AM »
Just take the OEM #, and google around that. you will find all sorts of claimed sizes. Take any one of them, and google that. it goes in circles w/ no clear winner. I think one of the formula programs will be the best approach to something that makes sense. If you can use 1 to get your stock size then you can work it from there to modify 1 or the other.
« Reply #26 on: May 31, 2010, 04:35:16 AM »
...i've seen at least a half-dozen different claims....
..i'm sure they must all "work", but one size must be "optimum...
« Reply #27 on: May 31, 2010, 08:35:06 AM »
I just realized I only got you by 4 posts. (w/ the spot)   Perhaps an old belt wraped around both pulleys, and cut in the top center can give you a good idea. Going by the old # add the missing mm's to a new #
« Reply #28 on: May 31, 2010, 11:58:42 PM »
..i gotta go ahead and get the cvt kit..
..i have 30,000 miles on my stock clutch, and my malossi variator is a little better than junk...
..ramp plate hole is not true...sliders are shot... those damaged areas on the 3 bosses are triple what they were in thos pics from a few months back...my rollers are wearing at a slight taper...
..the NCY has GOTTA be an improvement overall...
« Reply #29 on: June 01, 2010, 06:28:10 PM »
Just a thought! Contact Malossi, and fill them in. They may do a Gratis swap, or have an idea for a Malossi over-range kit for you. Try one of the phone #'s for the headquarters in Italy as they are the ones in charge. I realize the var doesn't owe you anything, but it may be interesting to see what they say. Tech support would be my first attempt.
