Author Topic: Driven Face spline teeth stripped  (Read 13081 times)
Lammy1000
Re: Driven Face spline teeth stripped
« Reply #15 on: May 29, 2010, 01:12:36 PM »
This is getting really bizarre. I have the belt installed, utilizing the suggestions here and when the bike is started the belt stays in the high speed position. That is, the belt stays near the outer circumference of the drive faces and the inner circumference of the clutch faces. Its as if the movable face on the variator will not allow the belt to slip inward, reducing belt tension on the clutch. I am very perplexed, please offer advice.
« Reply #16 on: May 29, 2010, 09:16:56 PM »
...take some pics if you could....
..okay, so you put on the moving pulley and ramp / roller / face seal cover assembly...slip the belt onto the shaft..at this point, the belt should be against the moveable drive face pulley, and hugged around the shaft collar....
..next, install the non-moveable drive face, washer and nut, making sure the drive face is seated against the collar...should squeeze against the belt...
sidthesloth
  • Kymco ZX50
« Reply #17 on: May 29, 2010, 10:35:55 PM »
From what I read of this it sounds like there is something stopping the movable face from going back as it should, maybe a slider turned during install or something else, it would be worth going back over it again and checking all the details.
« Reply #18 on: May 29, 2010, 10:36:59 PM »
..i agree, something is out of place....
..that's a really compact looking variator...
..wonder if sliders will even work right in it....
sidthesloth
  • Kymco ZX50
« Reply #19 on: May 29, 2010, 10:42:43 PM »
I have missed something, I don't see any pics or links...???
« Reply #20 on: May 29, 2010, 10:44:39 PM »
..i googled the service manual...
"http://mpsracing.net/helix-manual/08-07.html"
sidthesloth
  • Kymco ZX50
« Reply #21 on: May 29, 2010, 11:00:46 PM »
Cheers, there appear to be two bearings? that are not noted.
« Reply #22 on: May 29, 2010, 11:05:38 PM »
..i think those are seals...
sidthesloth
  • Kymco ZX50
« Reply #23 on: May 29, 2010, 11:07:11 PM »
OH! :-[
« Reply #24 on: May 29, 2010, 11:07:29 PM »
..he also said he has a "ring" (first post) against the oil seal that i do not see anywhere in the diagram...
« Reply #25 on: May 29, 2010, 11:08:40 PM »
...look at page 8-5...
..that's one tight variator...
sidthesloth
  • Kymco ZX50
« Reply #26 on: May 29, 2010, 11:11:09 PM »
Yes, I had noticed that but I had not seen the diagram. Deffinately sounds like the face is not moving
maybe incorrect size rollers/sliders? Just another possibility. Maybe put it back to original and see what that does, get a better idea of what is happening?
« Reply #27 on: May 29, 2010, 11:14:31 PM »
...that's a good idea, if the original rollers are intact..
..at my first roller change, there wasnt very much left of the rollers...
..30,000km...
..there's pics of them here, i think...somewhere around july 09...
..it was ugly....
sidthesloth
  • Kymco ZX50
« Reply #28 on: May 29, 2010, 11:15:34 PM »
that is tight, maybe sliders won't work in there, as you look at the pic the point on the slider goes in toward the centre so maybe not letting the variator retract fully.
« Reply #29 on: May 29, 2010, 11:20:29 PM »
..i think you r right....
here's that pic...
« Last Edit: May 29, 2010, 11:28:25 PM by wordslinger »
