Author Topic: Driven Face spline teeth stripped  (Read 13082 times)
sidthesloth
  • Kymco ZX50
Re: Driven Face spline teeth stripped
« Reply #30 on: May 29, 2010, 11:24:04 PM »
Maaate, was that your's, I bet you really loved your new rollers.
« Reply #31 on: May 29, 2010, 11:27:10 PM »
..yup...there's no telling what all that would have become, if my belt had not broken...
...i was the ultimate newbie...
Hoolander2
« Reply #32 on: May 30, 2010, 12:38:48 AM »
Here's a pic from Dr. Pulley site.
« Reply #33 on: May 30, 2010, 12:43:06 AM »
The sliders have a triangle shape on one end and a "u" shape on the other. I placed the triangle side into the housing because a triangle shape recess seemed to be there...is this correct? Thanks for your help.
..wonder if he installed them correctly....
sidthesloth
  • Kymco ZX50
« Reply #34 on: May 30, 2010, 04:35:05 AM »
When I first saw that I thought I put mine in wrong but then I realised there was something behind, it is a cut away view. Here is the label that came in the pack.
« Reply #35 on: May 30, 2010, 04:39:39 AM »
...i think he installed his at a position of @ +90 degrees clockwise to that pic....
« Last Edit: May 30, 2010, 05:08:05 AM by wordslinger »
sidthesloth
  • Kymco ZX50
« Reply #36 on: May 30, 2010, 04:51:11 AM »
Ah, see.
« Reply #37 on: May 30, 2010, 05:08:29 AM »
...i meant clockwise...
Shaka
« Reply #38 on: May 30, 2010, 05:09:00 AM »
I think he definitely put them in upside down.  When my variator notching experiment went awry, the slider got flipped upside down and it did exactly what Lammy is describing. It got stuck in high gear!
« Reply #39 on: May 30, 2010, 05:11:35 AM »
...the voice of experience lammy..
....we've all been speculating up to this point....
Lammy1000
« Reply #40 on: May 30, 2010, 03:22:34 PM »
 Helix is up and running again!! I was allowing the ramp to move outward during install and the fixed face was stuck in the high speed position, preventing belt from moving toward the centerline/low speed position.  Thanks for all the replies.  I am going to put a few more miles on this machine.  By the way, why is it that afetr getting into scooters 2 months ago I rarely want to ride my Yama FZ1?
« Reply #41 on: May 30, 2010, 03:30:47 PM »
...awesome lammy!!!!
 ;D
..it's a bug...we all have caught it!!
Lammy1000
« Reply #42 on: May 30, 2010, 04:30:18 PM »
Bike is running great except when starting from a stop there is alot of shuddering/bogging down. I did not touch the clutch or even remove it during this maintenance period and the machine only did the normal small amount of scooter shudder prior to this.
I removed the clutch bell and cleaned that and the pads which were just in tolerance. The bike runs as strong as ever at speeds >16 mph, but below that it shudders and feels like the engine isn't pulling enough rpm's.
« Last Edit: May 30, 2010, 09:10:26 PM by Lammy1000 »
« Reply #43 on: May 31, 2010, 02:16:18 AM »
It may be the clutch, or belt slipping. The quicker closing of the var may bee adding extra load that you did not have before. You may want to try adding fly springs, and a contra spring to finish out the cvt
Hoolander2
« Reply #44 on: May 31, 2010, 02:17:31 AM »
Have you just now installed the sliders?  Could they be slightly different weight from stock rollers?  Heavier, maybe?
