Author Topic: MY ZX50 O.E.M CARB TUNING  (Read 54363 times)
Re: MY ZX50 O.E.M CARB TUNING
« Reply #15 on: June 01, 2010, 02:40:09 AM »
I stopped reading 1/2 way thru. Youibhae enough posts to carry us thru this. Show us all the ball$$.
« Reply #16 on: June 01, 2010, 02:42:15 AM »
..batman and th' hippie grass...
« Reply #17 on: June 01, 2010, 02:47:14 AM »
Tyhat wiould  Be Mainl,y Hkkiipppikd Grass!~
« Reply #18 on: June 01, 2010, 02:48:10 AM »
...  ;D :D :o :D ;D ...
..there's a skeeter feasting on my ankle...dammit...
thebatman
« Reply #19 on: June 01, 2010, 02:51:05 AM »
show balls???     hippie grass??    dam, i muxt be burnt the f out!!!!
"THE BAT"MAN...
Says:
« Reply #20 on: June 01, 2010, 02:51:53 AM »
..i reckon we all are....
sidthesloth
  • Kymco ZX50
« Reply #21 on: June 01, 2010, 04:24:50 AM »
With regards to the jet, I think I may have seen the ones you are talking about and was wondering if they screw  in with the head outside. Get one and try it. Only $2.50, I am paying $4.50 here.
thebatman
« Reply #22 on: June 01, 2010, 07:28:21 PM »
well, yet again i get beat down...been lookin for jets to rejet carb...cant find any like mine, seen all sorts of them tho.   guess my kiehin is oddball...dam, may as well give the f*** up!!!!!     i get a 150cc, i bet i can go 50+!!!
"THE BAT"MAN...
Says:
« Reply #23 on: June 01, 2010, 07:45:34 PM »
http://www.weldfabulous.com/Weldcote-Metals-King-Torch/Torch-Tips-Accessories/Miscellaneous/-p6122039.html   Try the tip cleaners Bro! They will save a lot of grief. You will have EVERY JET YOU WILL EVER NEED for the price of 1 jet.
Shaka
« Reply #24 on: June 01, 2010, 10:47:05 PM »
Try this link, they have "every" Keihin carb part!  http://keihincarbs.com/parts/jets.html  You will probably need to pull your jet out and measure it to be certain.  Otherwise, I guess I can pull mine out of my spare for you if I find time.
sidthesloth
  • Kymco ZX50
« Reply #25 on: June 02, 2010, 12:06:19 AM »
Hey zombie, that is the same set I am using, (though mine has a blue cover), I could not work out what size each one was so I just measured with verniers. I was hoping to find a set of drills in the size range I needed but that was what I came up with, mine were $8.40, the drill bits, which only had two sizes usable to me were $42.
« Reply #26 on: June 02, 2010, 03:34:08 AM »
That's what I'm talking about Bro! I used drills for many years until a buddy of mine hooked me up w/ the tip cleaners. Much cheaper, and just as easy.
bniesen
« Reply #27 on: June 03, 2010, 07:14:35 PM »
SO...I'm trying to adjust my stock carb and I got the Idle screw adjusted but when I try to adjust the air mix (small) screw there is little to no response in the idle.  Is this a sign of something bad or just because its a crappy stock carb (2005 people 50 2t)
bniesen
« Reply #28 on: June 03, 2010, 07:17:24 PM »
by the way, Zombie, Shaka, Word, Batman, all the other "regulars" that put the info/links on this forum.  Thanks from all us noobs, we gotta learn from somewhere, right?
Thanks again for the knowledge.
thebatman
« Reply #29 on: June 03, 2010, 08:10:56 PM »
what up?  i have one out, i did measure it, MY measurements came to 8.48mm long, 5.61 wide, 5.86 thick????  these dont have the actuall head, just the slot for screwdriver, goes INSIDE "jet holder".   thanks for the link, ill go scope it out......    hey zombie, i could use those to clean a carb, not to jet.. you the man there homey.. supposedly i messed up that extra jet i do have. idk?? my drill set was $15 for the micro bits, no dam sizes on bits tho.
"THE BAT"MAN...
Says:
