G'day batman, that with the revs creeping up and down, you don't suppose that could be the belt slipping do you? Under load it slips and then grips, while your speed stays the same your revs change, as it gets worse, your speed will be affected more. Think of a slipping clutch in a car. When I bought my Hilux, in top gear, if you put your foot down the revs would increase but the speed would only increase slowly. Just a thought.
