Author Topic: Oh boy...choice-choices  (Read 6842 times)
shubonker
    • a motorcycle blog
Re: Oh boy...choice-choices
« Reply #30 on: May 31, 2010, 12:10:45 AM »
How about the one you already have?
« Reply #31 on: May 31, 2010, 12:24:25 AM »
...ummmm...wwwellll.....
shubonker
    • a motorcycle blog
« Reply #32 on: May 31, 2010, 12:31:40 AM »
Lol its cool man, no worries.
« Reply #33 on: May 31, 2010, 12:43:05 AM »
here's a tutorial showing how to dis-assemble your clutch without the compression tool....
"http://www.jacksscootershop.com/tutorials/clutch_installation.pdf"
sidthesloth
  • Kymco ZX50
« Reply #34 on: May 31, 2010, 12:55:24 AM »
That is a good link, but personally I would rather something a little more definate to hold the spring, especially during reassembly, you don't always have a second person around to help.
However I may even use that method if I need to.
« Reply #35 on: May 31, 2010, 12:59:12 AM »
...i'm not sure i would want to put a chain wrench on my clutch pads either...but a strap wrench would work...
...i have dis-assembled one time by myself without a compressor tool...
..don't want to do that again...
« Reply #36 on: May 31, 2010, 01:03:03 AM »
The easiest way for me is to loosen the bell nut first. (clutch still on the scoot) Them remove the clutch, and stand on the bell w/ both feet. You can remove the nut, and press down w/ one palm, and it comes right up w/ no suprises. Unless you are working on the second six pack... Then you get a split lip to remember it by. (Not that it ever happened to me!)
« Reply #37 on: May 31, 2010, 01:05:13 AM »
..split lip...lol..
..or a bleeding chin.......so i've heard....
« Reply #38 on: May 31, 2010, 01:07:33 AM »
Yeah man. Just heard about it.
shubonker
    • a motorcycle blog
« Reply #39 on: May 31, 2010, 01:43:19 AM »
I was referring to the clutch holder to get the bolt off.  I've already got the compression tool covered.
« Reply #40 on: May 31, 2010, 01:45:23 AM »
...oh!!!
...ok...
« Reply #41 on: May 31, 2010, 01:46:22 AM »
My bad... What I do is wrap a bungee around the rear brake lever. That locks up the clutch shaft. Either use an impact to remove the nut, or use a long ratchet handle, and hit it w/ a hammer to shock it loose. either one works fine
« Reply #42 on: May 31, 2010, 01:47:40 AM »
...that only lakes about 5 minutes to make....
shubonker
    • a motorcycle blog
« Reply #43 on: May 31, 2010, 02:14:12 AM »
Cool, i'll try that, thanks!
