Author Topic: How to set a digital tach?  (Read 776 times)
beermak
« on: March 07, 2016, 07:43:21 PM »
I just got a digital 10 buck tach. I installed but aint getting a real read.
I maneged to get a decent 1800rpm read at idle but a wot it gets 4000 give or take. It should be showing 7500/8000 ! Wot i believe...
The scoot is a rocket tops 115kph and its a like 125.
What configuration should i use??
Thanks
Re: How to set a digital tach?
« Reply #1 on: March 07, 2016, 08:00:46 PM »
If your scooter is a 4 stroke - it sounds like your tach is set for a 2 stroke.
Try the other setting (s) per the instruction sheet until you see a 8000 RPM reading at throttle.
My Tiny Tach had the same adjustments to make....then it worked fine.
beermak
« Reply #2 on: March 07, 2016, 10:36:09 PM »
I tried setting 1 2 and 3. One read idle at 900 then 1800 and then 3600.
1800 seemed the correct setting but at wot things looked odd.. 3700 was the most
Its either something im missing or just its crap this tach.
beermak
« Reply #3 on: March 08, 2016, 12:43:54 AM »
I tried setting 2 and seemed fine... idle was 1800 and reving got till 5500 on the stand. I will need to road test it... but lets hope it works.
