have you tried sliders, the same Wt. should give you lower RPM.
have you looked at the variator slides for the rollers ,. are the slides clean all the way out , where the rollers slide, and have you looked how high the belt go,s on the drive pulley, you do that with the cover off. and the bike on the center stand, and rev it up,. I even shaved 1 MM. off of each sides of the pulleys, because the belts are not wide enough 24 MM. wide and full spec. width is 25.2 MM. I use to wonder why my bike was always at 7,000 RPM and over at 60 MPH. now I can cruse at 55 to 6,000 RPM at 60 MPH,.
2011 downtown 42,000 miles and smiling
