Did you miss your
activation email
Technical | How To
Arduino Digital Touchscreen Dash
Topic: Arduino Digital Touchscreen Dash (Read 2601 times)
mclark999
Sr. Member
March 15, 2016, 02:55:09 AM »
I'm doing another arduino project and since I'm installing a Trail Tech CHT and Tach, I thought maybe I could do something more cool.
Check out this cool project.
http://www.janspace.com/b2evolution/arduino.php/2010/06/26/scooterputer
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
West Tennessee, USA
Re: Arduino Digital Touchscreen Dash
March 15, 2016, 04:02:12 AM »
That IS pretty cool! All that could include tire pressure as well.
mclark999
Sr. Member
March 15, 2016, 12:58:50 PM »
Quote from: CROSSBOLT on March 15, 2016, 04:02:12 AM
Good idea
Sent from my SM-G900V using Tapatalk
OEM 16mm carburetor
mclark999
Sr. Member
Reply #3 on:
March 15, 2016, 06:38:16 PM »
I may not do this full blown touchscreen Arduino, but I am going to give it a go to read a couple of things for me. I'm also working on an Arduino temperature logging for a solar furnace/hot air collector that I built last year. These Arduino projects are an excuse for me to get my geek on.
First I'm going to start with cylinder head temperature and RPM. I'll be doing a bit of documenting in this thread ahead of time for future resource.
For the CHT, I'm going to use this $8 thermocouple from EBAY
http://www.ebay.com/itm/380878984853?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Then I'll buy this Arduino compatible thermocouple module off amazon:
http://www.amazon.com/Arduino-MAX6675-K-thermocouple-module-temperature/dp/B0100A7SS6/ref=sr_1_1?ie=UTF8&qid=1458066767&sr=8-1&keywords=max6675
Edit: I ordered the newer MAX31855 from Aliexpress. Here's a link to how to use the thermocouple:
https://learn.adafruit.com/thermocouple/using-a-thermocouple
I'll be following Adafruit's advice for the Arduino hookup and coding from here:
https://learn.adafruit.com/thermocouple/overview
Here's a tutorial for the thermocouple output to an LCD:
http://www.instructables.com/id/K-type-Arduino-thermometer/
And of course, I'll have an Arduino board. I'll be starting out with a starter kit like this:
http://yourduino.com/sunshop2/index.php?l=product_detail&p=480
. I may buy a cheaper starter kit, but I've got a handful of projects I'm thinking of like a weather station, programmable thermostat, etc. so I may go big.
That's enough for now. I'll be adding another post for how to do the tach later. So far, my research on that hasn't given me real solid help.
Last Edit: March 21, 2016, 10:32:26 PM by mclark999
OEM 16mm carburetor
Eugene
Newbie
Reply #4 on:
March 17, 2016, 01:31:12 AM »
Wow! This is one bad @$$ gauge! Keep it up, man!
mclark999
Sr. Member
Reply #5 on:
March 18, 2016, 10:08:26 PM »
Here's a guy that made an arduino for his motorcycle that includes a tach, speedometer, and gear indicator
http://forum.arduino.cc/index.php/topic,8474.0.html
OEM 16mm carburetor
mclark999
Sr. Member
Reply #6 on:
March 22, 2016, 04:06:23 PM »
Here's another that appears to support some type of radar detector. That would be great to have.
[url][/https://forum.sparkfun.com/viewtopic.php?p=80410#80410url]
OEM 16mm carburetor
mclark999
Sr. Member
Reply #7 on:
March 30, 2016, 08:26:57 PM »
For the CHT, I'm going to display the temperature AND use an RGB led that will shine blue when the scooter is cold, green when it's normal and flashes red if it's overheating. Want it to get my attention
OEM 16mm carburetor
mclark999
Sr. Member
Reply #8 on:
April 04, 2016, 10:15:17 PM »
Arduino starter kit arrived from China. I'm going to be inching into it starting tonight.
OEM 16mm carburetor
mclark999
Sr. Member
Reply #9 on:
April 08, 2016, 08:33:42 PM »
Got the thermocouple amplifier and hooked it up. Works as a prototype. Need to add a display and make a box to mount it on the bike.
Then on to the tach.
OEM 16mm carburetor
lalek22pp@gmail.com
Newbie
Reply #10 on:
July 22, 2016, 11:25:01 PM »
I'm sure we all can use exploit Arduino for much more diferent aims
https://ikraz.biz/consumer-electronics/computers-accessories/arduino-scm-3d-printer-acc.html?product_list_limit=36
My son is only 11, but he loves "playing" with such devices, trying to build his own gadget.
Back
