Author Topic: What oil for gearboxes  (Read 1119 times)
Coach
« on: March 16, 2016, 02:06:52 AM »
I've heard that the factory oil in the gearboxes isn't really very good. What are you mechanically minded owners changing it over to?
Retired outdoor bum!
I like it too!
Re: What oil for gearboxes
« Reply #1 on: March 16, 2016, 02:21:14 AM »
what does your manual say ?  in my scooter I use # 90 full syn. oil , you can use it any time ,no break in time,  for gear boxes,
airshot
« Reply #2 on: March 17, 2016, 12:48:05 AM »
   I am assuming you are referring to the differential gears?  On my side by side I replaced the factory gear lube with full synthetic 75-140 gear oil. Most differential gear cases require an 80-90wt gear oil. By using a full synthetic gear oil you can use a broader weight lube as the syn products do not get thick in the cold like conventional dino oil does but they still control wear like a thicker oil does and even better under severe conditions.
beermak
« Reply #3 on: March 17, 2016, 01:02:11 AM »
I use synthetic manual transmision fluid 75w90. Change it every other oil change.
Driemeyer25
« Reply #4 on: March 17, 2016, 02:46:51 AM »
We use 80w-90w and Arctic Cat had there own oil. But you can use any brand.
