Did you miss your
activation email
Scooters - 125 to 300
Agility 125
Gear Oil Drainage Bolt Semi Stripped
Pages:
Topic: Gear Oil Drainage Bolt Semi Stripped (Read 3753 times)
Vision
Sr. Member
Re: Gear Oil Drainage Bolt Semi Stripped
Reply #15 on:
May 30, 2021, 04:06:55 PM »
My pleasure.
The resolution to this back in 2016 was to have a mechanic drill and tap the hole for a larger bolt. And each
gear oil
change use Permatex 82194 Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker, 3.5 oz. to seal the bolt.
Back
