Author Topic: Tecnigas Trek for People 2T  (Read 19206 times)
paceneedsstides
Re: Tecnigas Trek for People 2T
« Reply #15 on: April 06, 2016, 02:53:34 AM »
lol yep keeping them maintained and clean are best cheap upgrades there are.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
mclark999
« Reply #16 on: April 08, 2016, 01:40:18 PM »
Now I have to show some patience. I want to clean the carb, put it back on and see how it runs before I put the pipe on and rejet it. It's run a little lean ever since I bought it and I want the before and after comparisons to be fair.
Oh and I want to get my Arduino thermocouple working and do head temps too.
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
chaz35
  • old guy
« Reply #17 on: April 08, 2016, 02:42:44 PM »
Pipe looks good, good price, and reasonable shipping.  An easy bolt on mod!  Looking forward to how it runs.
I am not familiar with Arduino thermocouple?, I guess didn't go with TrailTech TTO.
mclark999
« Reply #18 on: April 08, 2016, 08:16:19 PM »
Here's the Arduino. It's a diy microcontroller. In the pic, you can see the spark plug adapter. The little chip connected to the red bread board is a thermocouple amplifier. It works now with output to my computer monitor. I need to get it to send to an led display so I can take it with me on the scooter.
OEM 16mm carburetor
paceneedsstides
« Reply #19 on: April 09, 2016, 01:06:46 AM »
I just use a Trail Tech CHT for mine so far have no issues with it works great
94 main jet
Malossi Multivar
Stage 6 upgear kit
chaz35
  • old guy
« Reply #20 on: April 09, 2016, 01:46:01 AM »
mclark, wow that's impressive, I have no idea how to do that.
mclark999
« Reply #21 on: April 09, 2016, 12:42:35 PM »
I didn't either a month ago, but it's open source and my friend Mr. W. W. Webb is a good teacher.
OEM 16mm carburetor
mclark999
« Reply #22 on: May 05, 2016, 05:39:26 PM »
Going to install the pipe this weekend. Will post pictures and my results.
OEM 16mm carburetor
paceneedsstides
« Reply #23 on: May 06, 2016, 12:05:23 AM »
 ;D
94 main jet
Malossi Multivar
Stage 6 upgear kit
mclark999
« Reply #24 on: May 08, 2016, 01:04:01 AM »
Looks pretty nice. The bracket is just thin stamped steel. Fit fine except one of the supplied bolts wasn't long enough so I'll have to get a longer one.
Much lighter than the 13.6 pound OEM exhaust. Forgot to weigh it before I put it on but I read online that it weighs 7.7 pounds.
Sounds pretty quiet. Didn't have time to rejet the carb yet so haven't ridden it.
« Last Edit: May 08, 2016, 12:36:15 PM by mclark999 »
OEM 16mm carburetor
mclark999
« Reply #25 on: May 08, 2016, 01:22:40 AM »
Here it is next to OEM.
OEM 16mm carburetor
mclark999
« Reply #26 on: May 08, 2016, 06:53:16 PM »
Well that was disappointing. I cleaned and rejetted the carb. Went up to a 95 main. Took it for a ride and I can't tell any performance difference.
It's supposed to make max power around 8500 rpm, but even on a long straight it's not getting above 7500.
I have 6 gram weights in the variator which tunes it to about 7200 rpm, so I'll probably have to go to 5 gram weights.
Any thoughts?
OEM 16mm carburetor
chaz35
  • old guy
« Reply #27 on: May 08, 2016, 08:18:18 PM »
Not sure what's going on, maybe your carb is smaller than mine, I don't know.  I think I was running 7 to 7.5g sliders in mine, worked great, but I was running 108 main jet.  Don't know what you weigh, but I am approx 175 to 180#'s.  Also, I was running Malossi variator, which seems to help keep revs up, compared to OEM.
I looked at the linked comparison chart, and until you get past 7500 revs, you will have no improvement.  Bigger carb, better pipe is all about making more revs.
Try the lighter rollers, I tried 5g in mine once and it rev'd to the moon, should get you to the powerband.  Let us know, good luck.  Cheers
mclark999
« Reply #28 on: May 08, 2016, 09:41:24 PM »
I had over jetted it. Stock People is supposed to have 82 main jet so I bought a 95 and 98 thinking one would be close.
When I took out the main, it was a 70. Very small but I am at 5000 feet here in Denver. Even so it had been acting lean at times. I did pull the plug before I started and it looked almost perfect for a plug with 1000 miles on it.
Since I didn't have a jet between 70 and 95, I used torch top cleaners to make an approximately 89 jet. It ran better, now seems a tiny bit lean.
Variator weights are keeping the ramp up to about 7300 or less rpm. Now it will keep creeping up in speed and when it hits around 7500, it really gets going.
 Before the pipe on the flat, I could hit about 42 on the speedometer which is probably about 38 mph. Now it will go beyond 50 indicated. I don't know how much beyond because I ran out of road.
I'll go down to the 5 gram rollers and go up just a bit richer on the jet and see how it does.
« Last Edit: May 08, 2016, 09:44:06 PM by mclark999 »
OEM 16mm carburetor
mclark999
« Reply #29 on: May 08, 2016, 09:42:22 PM »
BTW, I weigh about 175.
OEM 16mm carburetor
