Author Topic: re-jetting:  (Read 2261 times)
seeing304
re-jetting:
« on: May 31, 2010, 06:07:02 PM »
i have a 03 kymco people 50 2t. my problem is that i get the same speed at 3/4 throttle as i do at full. should i up-jet the main jet. help
"Keep The Faith"
Re: re-jetting:
« Reply #1 on: May 31, 2010, 06:16:01 PM »
...what is the speeds that you are egetting...
..has it ever been de-restricted?
seeing304
Re: re-jetting:
« Reply #2 on: May 31, 2010, 09:52:34 PM »
i have de-restricted my boss, cdi, and exhaust. i can run about 40 mph on flat.
"Keep The Faith"
Re: re-jetting:
« Reply #3 on: May 31, 2010, 11:34:43 PM »
...with the exhaust restriction eliminated, you may very well need to go up a size or two...
...do a WOT plug chop, and read your plug...that will tell you for sure..
..how many kms on your scoot??
« Last Edit: June 01, 2010, 12:06:33 AM by wordslinger »
seeing304
Re: re-jetting:
« Reply #4 on: June 01, 2010, 12:58:02 AM »
90
"Keep The Faith"
Re: re-jetting:
« Reply #5 on: June 01, 2010, 12:58:47 AM »
..umm..on the odometer...
seeing304
Re: re-jetting:
« Reply #6 on: June 01, 2010, 03:28:30 AM »
about 10000 miles
"Keep The Faith"
art
Re: re-jetting:
« Reply #7 on: June 03, 2010, 09:28:03 PM »
Hey was reading your post.Your top speed should be closer to 45+ if your pipe is a pre 2005 stock model.I would suggest new belt and rollers if you havn't done recently.Stock weights are 8.5,I would run an #85 main jet should get you close to 50mph.This worked for me on my 2002 I'm over 200lbs and of course check your tire pressure A few lbs low affects your top speed greatly.Good luck
