Did you miss your
activation email
Scooters - 125 to 300
Agility 125
Adjusting Rear Brake
Topic: Adjusting Rear Brake (Read 866 times)
Vision
Sr. Member
March 28, 2016, 10:09:36 PM »
How do you tighten the rear brake? I went to tighten the nut but the nut oddly rotates the entire bolt piece and a concave piece of metal under it. It seems to cycle the long bolt one rotation but not move anything.
Jim Moore
Jr. Member
Re: Adjusting Rear Brake
March 29, 2016, 10:15:53 AM »
the concave piece is part of the nut itself. As you turn it to the right it tightens the cable. Try two or three turns and see if you get any change at the lever.
Vision
Sr. Member
March 29, 2016, 11:03:52 PM »
I'll give it another try. I assumed you'd see some in/out bolt movement at the wrenching nut.
Back
