Author Topic: Crankcase Breather  (Read 1483 times)
sticlistul
  • Sex, Scoot and Rock 'n' Roll
Crankcase Breather
« on: June 01, 2010, 08:26:08 AM »
Look what I found guys :
http://www.centralscooters.co.uk/product_info.php?cPath=514_657_674_496&products_id=3210
It sounds like a very smart idea to me ,but I can't figure it out after you put one end of the hose in oil filter plug , the second end where do you fit ?
Hoolander2
Re: Crankcase Breather
« Reply #1 on: June 02, 2010, 03:16:32 AM »
On this particular one, I think it just terminates at the end of the hose provided.  Looks like that second blue adapter is probably/hopefully a small spark arrestor of some kind.  Yes, it does sound like a good idea.  I've seen a similar idea on Dragon Custom's site.  Theirs has a sort of bottle on the end of the tube to collect the oil vapors.
Only thing I'd be cautious of is to locate the end of the tube where any oil drops will fall away from the path of the rear tire.
I'm considering a mod to my breather hose which comes out of the valve cover on my X 500.  I don't like it pumping oil vapor into my paper air filter so I'm gonna disconnect it there and put a small spark arrestor on it and just let it breathe in the air.
« Reply #2 on: June 02, 2010, 09:18:21 PM »
..i've been discussing this very thing in scooterinvasion...
...the prevailing opinion is that a positive crankcase ventalation is desirable for better performance...
« Reply #3 on: June 03, 2010, 07:35:29 AM »
You Have to have it. A 4t would cease to be if you tried to seal the cases.
