Author Topic: Back fireing  (Read 3338 times)
Chris0381
Re: Back fireing
« Reply #15 on: May 12, 2016, 10:31:40 AM »
Exhaust leak at the flange ?? Incorrect fuel mixture ??
A little google of scooter backfiring came up with those.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
Re: Back fireing
« Reply #16 on: May 12, 2016, 08:13:36 PM »
Gentlemen, I need some advice. My DT 300i is a 2012, I got it in October '15. It has less than 1800 miles. I noticed these little cracks in the tire. I don't know how or where it sat before I bought it. Should I replace the tires? Or should I wait? You guys have helped me in the past, I trust your opinions! Thanks
    - Rich
Sent from my iPad using Tapatalk  its all good have a cup of coffe on me.....your tires are weather checked.I would get new befor you are left pushing the scoot home.
Re: Back fireing
« Reply #17 on: May 12, 2016, 08:18:29 PM »
Did some fine tuneing today. Soon as I turn the gas mix screw to about 11/4 turns the scoot runs its best. But only gos 30 to 35 mph...with it 21/4 turns or less I can do 40 to 48 but then the back fireing starts.....Look like I need to go up a size in my main jet.
Re: Back fireing
« Reply #18 on: May 12, 2016, 09:05:13 PM »
That mixture screw usually is for idle speed. You are on the right track with a larger main jet.
Re: Back fireing
« Reply #19 on: May 21, 2016, 11:17:42 PM »
Ok back to the backfireing.I pluged off the big hose that comes from the bottom of the main head.took for a small ride.and the back fireing is gone. What gives. Is it safe for the scoot to have this pluged up.
Re: Back fireing
« Reply #20 on: May 22, 2016, 01:32:46 AM »
Pic.
xsel777
Re: Back fireing
« Reply #21 on: May 22, 2016, 06:18:57 AM »
Pipster , If that is a maxxis tyre, run as far as you can from it.
I had maxxis on my 500 which also developed cracks like that,  but even worse, one right across the circumference.!
Also I noted that the front tyre developed uneven wear pattern.
In  my opinion, they are an inferior product.
Since changing to Michelin city grips, all such problems are non existent.
« Last Edit: May 22, 2016, 06:21:21 AM by xsel777 »
2wheelfun
Re: Back fireing
« Reply #22 on: May 24, 2016, 12:11:40 AM »
Back firiing = timing on most problemos, =premature/after detonation. Just a cause maybe?
