Author Topic: Kymco Super 8 50cc s Stroke 2014 - Need new Exhaust  (Read 1611 times)
westofrayne
« on: April 02, 2016, 10:42:54 AM »
Sorry to bother you but my son has a 2014 Kymco Spuer 8 50cc 2 Stoke ped, the exhaust muffler and fixings have rotted through and I need to replace the exhaust, I have purchase an exhaust from Racing-Planet.co.uk but there is a pipe coming down from under the seat that goes into a filter (?) then follows exhaust to the front.  The replacement does not have this, looking on the net most don't have it either , anuybody know where I can get an exhaust to fit this bike from???
mclark999
Re: Kymco Super 8 50cc s Stroke 2014 - Need new Exhaust
« Reply #1 on: April 02, 2016, 01:12:59 PM »
Just don't connect those pieces to your new exhaust. On mine, a previous owner had cut off the little pipe from the original exhaust and welded up the hole. You'll get a good performance gain.
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
Chris0381
« Reply #2 on: April 02, 2016, 08:16:49 PM »
I have a 2013 original exhaust I set aside after modding one from ebay. I didn't want to chop and weld my original in case it didn't come out well.
But wouldnt, you just want to plug that one pipe up and remove the canister I think it is.
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
mclark999
« Reply #3 on: April 03, 2016, 12:35:57 PM »
Yes, That's one way to handle it. Some people leave the canister and running so it looks like it passes visual smog check.
OEM 16mm carburetor
agoncalvesjr89
« Reply #4 on: April 11, 2016, 05:14:18 PM »
I have a 2013 s8 2t.    I ur doing 41 with the stock catalyst exhaust , u will do 50 with an aftermarket one. I recently got a really really good exhaust . NARAKU TRAFFIC for kymco 2t.   Its nuts. Added 8mph and massive throaty sound.... Added a huge amount of low end torque.
2013 SUPER8 2T 50
70cc MALOSSI KIT
STOCK CARB MAIN JET AT 98 , STOCK AIR BOX SNORKEL REMOVED.
NARAKU VARIATOR 6 GRAMS SLIDER / ROLLER COMB.
TECNIGAS NEXT R EXHAUST
SLIGHTLY LONGER THAN STOCK GATES DRIVE BELT.
TOP SPEED 50ISH , TONS OF POWER. 45MPH CRUISING
mclark999
« Reply #5 on: April 11, 2016, 07:27:12 PM »
Hope my Tecnigas Trek gives me similar results on my People 50
OEM 16mm carburetor
