Author Topic: Need wiring diagram for MXU 150  (Read 6678 times)
86trizinger
« on: June 01, 2010, 09:38:23 PM »
I need a wiring diagram for a MXu 150. I got a new GY6 engine but the stator harness is different. I don't have the original engine to swap parts on. Any help would be great.
Re: Need wiring diagram for MXU 150
« Reply #1 on: June 02, 2010, 04:07:22 AM »
Have you checked the general section under service manuals? All I have seen has it. If you need more help I will try to look a little deeper for you. It doesn't come up w/ a quick google.
« Reply #2 on: June 02, 2010, 09:33:09 PM »
..i searched for an hour for a service manual for the 150...
..found several for other cc, but not a 150....
sidthesloth
  • Kymco ZX50
« Reply #3 on: June 03, 2010, 06:13:32 AM »
Maybe covered by one of the others?
« Reply #4 on: June 03, 2010, 06:39:45 AM »
Here's the 250cc.  http://pdftown.com/search/node/mxu+150   Perhaps you dan get what you need from there
86trizinger
« Reply #5 on: June 10, 2010, 03:17:27 PM »
Here is my problem.. I got a new engine but the stator wires don't match colors or connectors.
I need the stator wiring diagrams for the colors of the wires.
To be more specific. I have the pulser wiring figured out. On the stator side there is 3 wires of different colors then what I have. Every diagram I look at shows all yellow.
The new engine has these colors on the Harness:
white/red
White
Black
The harness has these colors:
Black/red
pink
yellow
« Last Edit: June 10, 2010, 04:01:45 PM by 86trizinger »
« Reply #6 on: June 11, 2010, 08:05:27 PM »
The easiest way would be to do a resistance test on both stators. That will match up the outputs for you.
86trizinger
« Reply #7 on: June 16, 2010, 02:34:56 AM »
I don't have the original stator or I would just switch it over to the new engine
« Reply #8 on: June 16, 2010, 12:30:05 PM »
If it helps on the majorty of Kymco models, the white wire is the AC out to the regulator, the yellow is the lighting wire, and the black /red goes to the cdi. So the pink on your harness I assume replaces the white.
