New 2010 Yager owner here w/ only 800 miles.
Loving it so far.
The manual I have says .9mm, but the sticker on the battery access panel says .6-7mm.
What is correct? The oem NGK in there was gapped to .8mm (it has only 800 miles on it)
The -9 is suppose to be .9mm and that agrees with the manual, but conflicts with the sticker.
I also tried a Autolite XS4164 Iridium (suppose to be a DRP6ea-9 cross) but the engine runs worse with it.
Idles rougher, but does rev out just fine.
Wondering if adjusting the Autolite to spec will help or are those not good in this motor?
I run Iridium (NGK or Denso) in every other motor I own and I so am a true fan.
There is no DPR6EIX-9 but there is a 7 (colder plug). Denso has nothing in the 6 range.
Local parts guy said NGK use to sell a 6 Iridium in this size but stopped for some reason.
Anyone use a DPR7EIX-9 successfully or do I just stick with the oem copper NGK?
Yager200i says use a Pulstar HE1HT9 spark plug. How about those? They are new to me.
Thanks, Bill
