Author Topic: STARTING PROBLEMS  (Read 1475 times)
5029lee
STARTING PROBLEMS
« on: June 02, 2010, 12:18:38 PM »
I HAVE AGILITY 50CC 4 YEARS OLD AND ONLY DONE 900 MILES, I AM HAVING SOME STARTING PROBLEMS, IT WILL KICK UP AND BE FINE,THEN THE NEXT DAY JUST WANT KICK IN, THEN IT WILL, THEN IT WONT, ITS GOT A MIND OF ITS OWN, ANY CLUES,DO YOU THINK IT MAY BE THE STARTER MOTOR IS ON ITS WAY OUT, CHEERS LEE
« Last Edit: June 02, 2010, 12:21:50 PM by 5029lee »
shubonker
    • a motorcycle blog
Re: STARTING PROBLEMS
« Reply #1 on: June 02, 2010, 02:27:23 PM »
Do a spark plug reading, maybe it went bad.
« Reply #2 on: June 02, 2010, 09:07:12 PM »
..does the engine turn..does the starter motor turn???
...if neither, then check the connection at the inline fuse, beneath the floor panel...
peace
« Reply #3 on: June 03, 2010, 07:38:24 AM »
Go to the relay they use for the starter. They go bad all the time. You can try cleaning the contacts, and if that fails, a Cole Hersey or Bosch 30amp relay works  for about 1/3rd the cost of the kymco part.
