Author Topic: Need Left hand switch - horn and turn signals with harnesses/connectors.  (Read 629 times)
Chris0381
I was trying to remove the left hand switch. Seems like someone glues the top screw in there and the head go stripped. Attempted to turn it 90 deg to get better leverage and ended up cracking the front plate. The weight of the mirror is stressing it during the ride now and is shaking.
I am seeing a few and would like to know if a 2007 People would fit or what models will fit the 2013 S8??
If anyone knows a USA source, please let me know.
Thanks
In the mean time I'll try to drill and tap some screw holes for a small plate or do a gorilla glue job on it.
The side handle bar mirrors would be another solution.
« Last Edit: April 19, 2016, 04:31:52 PM by Chris0381 »
Stock pipe derestriction
Smooth Boss
6.5gm Dr Pulley sliders
Malossi Torsion Controller
Polini Variator
#95 Main Jet
Purple Malossi Contra Spring
