Author Topic: .. cylinder upgrade assy instructions ..  (Read 3501 times)
« on: June 02, 2010, 10:06:47 PM »
shubonker
    • a motorcycle blog
Re: .. cylinder upgrade assy instructions ..
« Reply #1 on: June 02, 2010, 11:11:31 PM »
Thanks!  This is going to come in handy!!!!!!
shubonker
    • a motorcycle blog
« Reply #2 on: June 02, 2010, 11:14:06 PM »
Hey slinger, you going to buy the malossi kit?  I might get it too if you try it first, lol.
If anything i'm going to pick up the NCY kit which is almost half the price.
« Reply #3 on: June 02, 2010, 11:21:02 PM »
..i know right!!!
..i haven't found a US supplier of the malossi kit yet...
..i like the polini too tho..it's a front-runner right now...
..the airsal kit shaka put on his bitch has worked well for him, and it's much less expensive...
...i'm ssso confused...
..i got 5 benjamins to spend, and i want to make sure i ain't gonna throw it out th' window..
..i depend on my scoot for my livelyhood...i gotta have my ducks in a row when i start this..
..can't have any unexpected surprises...
shubonker
    • a motorcycle blog
« Reply #4 on: June 02, 2010, 11:27:29 PM »
Do you need to do any machining to that airsal kit?  B/c of the difference in diameter?
Or is it just plug and play??
« Reply #5 on: June 02, 2010, 11:30:30 PM »
...it should be plug-n-play...so to speak...
...maybe i should look at it again...
..what did you see??
shubonker
    • a motorcycle blog
« Reply #6 on: June 02, 2010, 11:47:10 PM »
Service manual states on page 8-1, that the cylinder diameter is 50mm.  Airsal diameter is 47.5, so idk.
Wheres shaka when you need him?
« Reply #7 on: June 02, 2010, 11:57:06 PM »
..i've had that manual for nearly a year...
..one duck steps in line...
..thanx shubonker!!!....
« Reply #8 on: June 03, 2010, 12:10:24 AM »
Bore x stroke (mm) φ39.0 x 41.4..
...page 1-2 of tha A50 service manual...
shubonker
    • a motorcycle blog
« Reply #9 on: June 03, 2010, 12:14:53 AM »
Pretty sure this is what we need:
http://www.mhr-usa.com/cylinder-kits/50mm/airsal-50mm-4-stroke-cylinder-kit-for-kymco-vitality4t-people-s-50-agility-50.html
Specifically list agility 50 4t.  And its 50mm.  I think shaka uses 47.5mm kit b/c he's got a zx50 which may be a little different.
« Reply #10 on: June 03, 2010, 12:16:18 AM »
..so did the other.......
shubonker
    • a motorcycle blog
« Reply #11 on: June 03, 2010, 12:23:11 AM »
Hmm, you're right.  I sent provoscooter an email to see whats up.  Until then, lets see if shaka's got an answer for us.
« Reply #12 on: June 03, 2010, 12:24:04 AM »
..shaka don't do 4-strokes....
Shaka
« Reply #13 on: June 03, 2010, 12:45:36 AM »
Here I am!  ;D  I don't do four strokes sorry man!  I doubt you have to do any machining to get the kit to fit though.  It should just fit right on.  I see where it says that the diameter is 50mm.  I know on the 2T's the skirt of the cylinder just gets thinner as the bore diameter goes up.  I would assume the same on yours
sidthesloth
  • Kymco ZX50
« Reply #14 on: June 03, 2010, 12:54:13 AM »
I may be off track here but it seems you are talking about the cylinder bore size, it doesn't matter if it is 47.5 or 50mm, that will only alter your cc in the end. I guess it depends on what size you want to go for.
Should fit either way.
