Author Topic: new horn?  (Read 2309 times)
donjack
new horn?
« on: April 30, 2016, 05:04:09 PM »
I was forced to use my horn yesterday, yep, car driver!! luckily I was only doing about 15mph when she decided she wanted to go in front of me without letting me know first!!
a couple off blasts (toots!!) of my pathetic little horn and she had a rethink!!
anyway, I was wondering if anyone has upgraded their horns and has any recommendations please?
this is what I have been looking at.
 http://www.ebay.co.uk/itm/Stebel-Nautilus-Compact-black-for-cars-and-motorcycles-extremely-loud-/301944176238?hash=item464d467e6e:g:epgAAOSwAHZUM~7L
cheers,
Don.
TANWare
Re: new horn?
« Reply #1 on: May 01, 2016, 12:24:51 AM »
Looking at reviews they say it is a bit bigger than the stock one so you may have to relocate. Also it draws 13.5 amps so it will need its own power supply line and relay for activation.
« Last Edit: May 01, 2016, 02:58:13 PM by TANWare »
donjack
Re: new horn?
« Reply #2 on: May 01, 2016, 07:01:27 AM »
Thanks for the reply TANWare, maybe just a little too much work with my limited electrical knowledge! And space is certainly at a premium in the nose area!
Another couple of manufacturers came up in the search, PIAA and FIAMM, I will search a little bit more I think!
Cheers,
Don.
Re: new horn?
« Reply #3 on: May 01, 2016, 08:09:58 AM »
  I have the Wolo air horn,  and It is big, to big for the same place as the old horn,  I am looking for a good place to put it, got the front end off, and I may put it under the ignition switch on the right side,.  there is a space inside there, will have to glue a bracket to mount it on,   ABS glue is strong , I hope,    one other spot is on the outside just over the rad.  behind the front wheel,.  don't know how long it would last there , are they water tight,
TANWare
Re: new horn?
« Reply #4 on: May 01, 2016, 03:02:38 PM »
Even louder dual horns may be a big help. I rarely ever get to use the horn, my first thought e ver is to do a defensive move and by the time I get to the horn the event is over.
donjack
Re: new horn?
« Reply #5 on: May 01, 2016, 07:07:41 PM »
hey De Dee, had a look at those wolo bad boys, much the same appearance wise as the stebel nautilus, but it says in the description that you only have to swap the wires from old to new, is that right?
http://www.ebay.co.uk/itm/Wolo-Bad-Boy-Dual-Tone-Air-Horn-Black-419-/262183579636?_trksid=p2141725.m3641.l6368
TANWare, I know what you mean! I usually blast (toot) my starter motor at them!! its an age thing!!  ;D ;D ;D
Re: new horn?
« Reply #6 on: May 01, 2016, 07:46:23 PM »
For what it is worth, I used a Wolo from Harbor Freight on the DT and it is bigger and requires an offset to bolt NEAR where the original squeeky horn went. It is WAY louder than original and sounds great! It does require a #12 wire from battery and a fuse, of course, and a relay since it draws more current than the original. It is not hard to rig but does take some time. If I was not such a dunce about getting pictures on here I would have posted it when doing it. I thought it was worth it.
Re: new horn?
« Reply #7 on: May 01, 2016, 09:19:36 PM »
  I just pluged the same wires on it ,. and don't play with the horn , it would get the wires hot, quick blast and it is OK.  safest though is # 12 wire from the battery with a relay and fuse
TANWare
Re: new horn?
« Reply #8 on: May 02, 2016, 01:55:01 AM »
If the wires are getting hot not only is it unsafe but it means the wires are acting as resistors. The horn is not as fast acting or loud as it can be either.
donjack
Re: new horn?
« Reply #9 on: May 08, 2016, 06:05:12 PM »
hello again guys, I bought these as a tester, at a tad over £5 I thought I would give them a go.
http://www.ebay.co.uk/itm/400844812035?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I installed them last night and they sound brilliant and loud, but, there is always a but isn't there!!
this morning whilst showing off to wifey, the first couple of blasts were perfect, she pooed herself!! (only kidding!!) on the third blast one of the horns sounded flat/ muted, I don't know what the problem is/ was and I was hoping one of you guys knew what is wrong?
any ideas gratefully received!!
thanks for your help.
cheers,
Don.
Mr. Paul
Re: new horn?
« Reply #10 on: May 08, 2016, 08:02:21 PM »
Hello Don. Chances are good that one of your horns is contacting part of the scooter body giving it that "squished" sound. Check around your horns to make sure you have some clearance then re-test it. I had the same problem myself.
2009 Kymco People 150
1993 Honda Helix
donjack
Re: new horn?
« Reply #11 on: May 08, 2016, 08:13:54 PM »
Thanks for the info Mr Paul, I will check it out tomorrow and post back.
Cheers,
Don.
donjack
Re: new horn?
« Reply #12 on: May 09, 2016, 10:55:01 PM »
Mr Paul, you were right! opened the front and checked, and sure enough one of the horns was touching the framework. so I relocated one of the horns, see picture.
it now sounds amazing!
I have uploaded a short video to YouTube.
mclark999
Re: new horn?
« Reply #13 on: May 10, 2016, 12:18:46 AM »
Love the sound and not trying to minimize your work, but other drivers may not be able to tell it's you, on a scooter, honking at them.
I've sort of learned this because I have a scooter horn on my bicycle and sometimes jay walking pedestrians don't figure out it's me honking at them and will walk right out in front of me with my horn blaring.
Sent from my SM-G900V using Tapatalk
2007 Kymco People 50 2T
Tecnigas Trek exhaust
OEM 16mm carburetor
Mr. Paul
Re: new horn?
« Reply #14 on: May 10, 2016, 01:43:01 AM »
They sound great! Glad you sorted it out.
1993 Honda Helix
