Author Topic: Bad cdi symptoms  (Read 3665 times)
allanseth23
Bad cdi symptoms
« on: May 09, 2016, 10:34:38 AM »
Hello everyone. Has anybody experience a failing or bad cdi? What are the symptoms? My b&w250 idles fine. But on sudden acceleration it lacks the kick of a 250cc its like accelerating on high gear, full throttle is like the same as half throttle no passing of power, ignition timing is off the mark using timing light. Any thoughts or comments.
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: Bad cdi symptoms
« Reply #1 on: September 15, 2016, 04:39:42 PM »
I doubt it is the CDI which is all electronic with no moving parts.  Most likely a vacuum leak or possibly vacuum leak in the diaphragm which makes the slide of the carburetor fail to lift which cause the exact symptoms you are describing.
Did you ever figure it out?
PaulC
GeraldSot
  • AntoniozerIV
Bad cdi symptoms
« Reply #2 on: March 27, 2019, 03:21:10 AM »
Anyone have experiences with a bad fuel pressure regulator/damper? If so, what are some common symptoms?
« Reply #3 on: March 27, 2019, 03:12:49 PM »
What are you experiencing and on what machine are you experiencing it?
Viper254
  • Moped Pirate
« Reply #4 on: April 05, 2019, 06:45:43 PM »
Have you got a belt and roller type drive? If so, perhaps the rollers are worn? Very cheap fix if so...
Rides;
Suzuki GW250 Inazuma (2016)
Honda C70C (red, 1983)
