Did you miss your
activation email
Scooters - 50cc
Why is there a gasket in the cover thats in front of variator and clutch?
Topic: Why is there a gasket in the cover thats in front of variator and clutch? (Read 646 times)
Mareks
Newbie
May 13, 2016, 10:50:26 AM »
So I took off my variator cover to change my rollers but the gasket broke!!! I dont understand why is there a gasket after all because on a lot of other scooters there arent? Can I just run without it?
JayAre
Jay Are
Full Member
Re: Why is there a gasket in the cover thats in front of variator and clutch?
May 15, 2016, 12:58:24 AM »
Your "clutch" is a CVT, Constant Variable Transmission. Dirt is an abrasive that will cause wear!
My wife never asked, " can you make it go faster?" until we bought a 4 stroke Moped. My reply, "yes dear"
2013 Agility 50 de-restricted with 72cc piston & head.
2-2005 Yamaha Zuma's 50cc 2 stroke bone stock
xsel777
May 15, 2016, 07:05:58 AM »
What JayAre posted is correct.
You can ride without it, but you will have to inspect the tranny more often, especially after going through dusty terrain.
JJJoseph
Kymco Sento
Reply #3 on:
May 24, 2016, 06:29:47 AM »
You'll get water in the case when you ride through deep puddles. The clutch/variator will slip for a while and then dry out. You'll feel silly while it's thrashing away trying to shed the water.
Back
