Author Topic: Too much gas??  (Read 773 times)
codger78
Too much gas??
« on: June 04, 2010, 08:25:50 PM »
It's easier just to crank the gas all the way over to go at max. speed (30mph+-), but today I noticed that I can get up to  speed when the handle is about 30% less then that...Question is... am I somehow wasting gas by cranking it as far as it will go...or is the gas flow regulated to just supply enough regardless??
borrowed dust
Re: Too much gas??
« Reply #1 on: June 04, 2010, 08:47:13 PM »
..as a general rule, less throttle equals less fuel consumption...
..do you get up to speed in the same distance with different throttle positions?
codger78
Re: Too much gas??
« Reply #2 on: June 05, 2010, 02:04:11 AM »
I think I throttled all the way from standing to top speed to start.  What I noticed was that once at top speed (33 mph on the meter along level roadway)if I rotated back about 20 to 30 degrees there was no noticed difference in speed or engine sound.  Farther back than that, and the speed would start to drop.  Going up a grade I throttled all the way to get the most power and speed, but even there I'm not sure that I had to......I guess it will take more time to get a better answer.
Oops...I should not have used % in my question.
« Last Edit: June 05, 2010, 02:08:14 AM by codger78 »
borrowed dust
Re: Too much gas??
« Reply #3 on: June 05, 2010, 03:11:03 AM »
You're not derestricted. The fuel is going to waste. If you do the mods, and open the scoot up it will make a huge difference.
