Author Topic: what rpm is safe for a lc engine  (Read 1575 times)
k50
« on: May 26, 2016, 02:05:40 AM »
my new super 9 lc is derestricted and has a technigas pipe.  i dont think the carb was touched.
on the flats i can get her going 50 but the rpm's are at 10k, is it ok to run the engine this fast?  if so, for how long?
i understand that with the liquid cooling it protects the engine more than air cooled, but 10k seems pretty fast.  and down hill, it may even go 11k, i never pushed it to that limit.
thoughts?
chaz35
  • old guy
Re: what rpm is safe for a lc engine
« Reply #1 on: May 29, 2016, 04:43:53 PM »
I suggest you look at the plug, do plug chop, see if running lean.  I think OK to run hard if not too lean.  I turn approx 10,000revs fairly often, but not for long.  I don't worry about it much, but will wear out engine faster.  These engines are fairly easy and cheap to rebuild IMO.  When cruising, I like to keep it around 9,000revs or below, with my CVT setup is approx 45mph, a good speed for where I ride.
Rage
« Reply #2 on: November 08, 2016, 11:18:45 AM »
I ran mine at 10k+ rpms for about 2 years and 20-40 miles a day. Finally blew head gasket
beermak
« Reply #3 on: November 08, 2016, 12:42:56 PM »
Id worry more if its lean at high rpm or if it has not enough oil...
then enjoy it and dont worry on rpms
Enviado desde mi iPhone utilizando Tapatalk
