Author Topic: Valve stem  (Read 1130 times)
TroutBum
  • 2012 Like 200i (sold)
Valve stem
« on: May 29, 2016, 12:30:03 AM »
On the front tire of my Like the valve stem is 90 degrees for ease of access whereas the rear is standard. Yesterday while checking the pressure the front stem moved side to side. I don't recall that happening before, but I generally hold the stem while getting a reading. I checked for a leak around the stem, but there was none. Is the stem suppose to pivot from side to side?
Re: Valve stem
« Reply #1 on: May 29, 2016, 11:39:36 PM »
Yes, mine does the same if I don't support it. (I'm assuming you don't mean that it is able to spin or pivot around in a circle in the hole of the rim?)
It doesn't leak - I always stipulate installing new valve stems with every new tire.
LidoCA
  • I LIKE chinese plastic.
Re: Valve stem
« Reply #2 on: May 30, 2016, 04:54:19 PM »
It would be nice if the rear tire had the 90 degree bent valve stem. It is a little awkward to get to.
Steve
2013 LIKE 200i LX.
2016 Yamaha SMax
2014 Yamaha Majesty
La Mirada, Ca.
TroutBum
Re: Valve stem
« Reply #3 on: May 30, 2016, 06:41:06 PM »
"Yes, mine does the same if I don't support it. (I'm assuming you don't mean that it is able to spin or pivot around in a circle in the hole of the rim?)
Stig"
I'm able to pivot it side to side approx  170 degrees.
"It would be nice if the rear tire had the 90 degree bent valve stem. It is a little awkward to get to."
The next time I replace my tires I'm going to have both rims mounted with new 90 degree stem.
« Last Edit: May 31, 2016, 04:09:09 AM by TroutBum »
Re: Valve stem
« Reply #4 on: June 12, 2016, 04:27:48 PM »
Stig"
Yeah, I bought a psi gauge with a  right angle tip on a short hose.....
Have been told that angled air nipples are stressed at high speeds.....which is the singular reason I never go for any land-speed-records on my LIKE200iLX.
