Author Topic: Front Brake Switch?  (Read 2864 times)
Lammy1000
Front Brake Switch?
« on: June 05, 2010, 10:31:20 PM »
The front brake switch on my Honda Helix can be heard "clicking" when the brake lever is pressed, but the brake light does not illuminate. Rear brake light works. I have never had this problem after many years of motoing...any ideas?
I know this is a Kymco site, and I have a Kymco "in the family"...my wife's (unless I'm granted permission to ride it.  Luckily she is well balanced and will share).
Re: Front Brake Switch?
« Reply #1 on: June 06, 2010, 02:21:05 AM »
..the rear lamp is a dual element..it's possible that the "brake" element has blown...
Hoolander2
« Reply #2 on: June 06, 2010, 03:32:54 AM »
Try to locate the switch and spray some electrical contact cleaner or WD-40 into it.  Maybe just dirty contacts inside it.  Otherwise it may be a loose or corroded connector leading to/from the switch. Can't be a bad bulb or filiment if it works when back brake is applied.
« Reply #3 on: June 06, 2010, 03:39:33 AM »
..think he meant the running light works, but will not brighten when the brake is applied...
..that would mean that both switches were failing, which is unlikely..
..just speculating..
« Last Edit: June 06, 2010, 03:41:21 AM by wordslinger »
« Reply #4 on: June 06, 2010, 03:49:25 AM »
You have to open the fairing to see if there is power to the switch/out of the switch.A cheap multi meter is something you should have as it will pay for itself in one repair. The switch is an easy replacement if needed, but you have to verify power first.
« Reply #5 on: June 06, 2010, 03:50:38 AM »
..but the more i read the post, maybe he means the right hand  lever doesn't  work, but the left hand does....
Lammy1000
« Reply #6 on: June 06, 2010, 10:16:40 AM »
Yes, the rear brake light illuminates when brake is applied.  The front brake lever does not activate the brake light.
Lammy1000
« Reply #7 on: June 06, 2010, 10:18:23 AM »
I will try this.  Thanks.
Lammy1000
« Reply #8 on: June 12, 2010, 07:50:26 PM »
As a follow-up...When I shorted the 2 wires going to the switch the brake light illuminated.  So I removed the switch f/the handlebar and sprayed contact cleaner in it.  A little light lube was sprayed in there and now the switch works...scootering.
« Reply #9 on: June 12, 2010, 10:38:48 PM »
...awesome lammy...
 ;D
« Reply #10 on: June 14, 2010, 01:39:26 AM »
You Da Man~
