Author Topic: Gear oil level  (Read 1159 times)
newby
Gear oil level
« on: June 10, 2016, 03:04:56 PM »
I dont have a manual. But i need to change the gear oil. Can someone PLEASE tell me how much to put in? THANK YOU! 👍
ScooterLar
Re: Gear oil level
« Reply #1 on: June 10, 2016, 03:43:51 PM »
180cc
2005 Grand Vista
2006 Vespa LX 150
2009 Grand Vista
2006 People 250
2013 Like 200
2013 Like 200 LX
2012 Genuine Buddy 170i
2009 Genuine Buddy 125
newby
Re: Gear oil level
« Reply #2 on: June 14, 2016, 02:23:11 PM »
Thank you! 👍
Grumpy old man
Re: Gear oil level
« Reply #3 on: July 06, 2016, 11:08:29 PM »
The best method for adding gear oil is to use a large syringe you can purchase them from any farm supply store.  I simply fill the syringe with fluid holding my finger on the squirty end and then insert the plunger a bit invert the syringe remove my finger and let a little air escape and then place it in the hole and squirt away repeat as needed and you have a quick and accurate method of filling the gear oil as the syringes are marked in ml's.  I prefer to use Amsoil 75-90 super gear lube.  it will last forever and not need changing.    Jim.    https://www.amsoil.com/shop/by-product/gear-lube/severe-gear-75w-90/
« Last Edit: July 06, 2016, 11:16:11 PM by Grumpy old man »
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
Re: Gear oil level
« Reply #4 on: September 15, 2016, 06:10:03 PM »
The best method for adding gear oil is to use a large syringe ...[/url]
Absolutely.  You draw up the exact 180cc then inject it.  Also, don't add more than 180cc as many people are tempted to because they feel 180cc is too little.  Follow directions in the manual and do it right.
PaulC
