Author Topic: Malossi carbon reeds  (Read 1583 times)
yogi
« on: June 06, 2010, 01:27:01 PM »
Hi fella's,
Just having a look on the net and have found some carbon reeds from Malossi, are they worth an upgrade with the standard carb and will it make much improvement :-)
Cheers
Pete.
Re: Malossi carbon reeds
« Reply #1 on: June 07, 2010, 01:45:29 AM »
Get a set of Boysen .030 stock carbon fiber blanks. They are lighter/quicker than the stock kymco, and better quality than the Malossi. They are easy to trace on, and cut out. Use quick cure epoxy to re-seal the edges you cut, and they will make a big difference in overall performance. Post more about it if you have any ?'s about cutting your own reeds.
