Author Topic: Stator Issue?  (Read 1626 times)
Vision
Stator Issue?
« on: June 17, 2016, 12:54:59 AM »
Is it possible that a new stator could be burning out the daylight running head light? But not affecting the bright? Maybe because it's not on as much?
Re: Stator Issue?
« Reply #1 on: June 17, 2016, 01:27:53 AM »
  check your voltage, the regulator could be putting out high voltage, and burning the light , and try a LED light in it,.
Vision
Re: Stator Issue?
« Reply #2 on: June 17, 2016, 01:36:13 AM »
Where do you get an LED light?
xsel777
Re: Stator Issue?
« Reply #3 on: June 17, 2016, 06:59:16 AM »
I got mine from banggood.com, free shipping worldwide. Dx.com is another option, or aliexpress.com. Dirt cheap, so get 2.
Vision
Re: Stator Issue?
« Reply #4 on: June 17, 2016, 10:38:54 PM »
Can you provide a direct link? I don't see it on banggood.
xsel777
Re: Stator Issue?
« Reply #5 on: June 18, 2016, 06:54:26 AM »
This is the direct link. H4.
Note the big bulge at the rear.,so make sure it will fit, plus it's wires, and original connector, in the space available.
It house electronics and a fan.
It needs more space than the original bulb.
It comes with 3 different plates, and I had to drill a hole in the headlamp housing (hidden area) to secure it.
The original waterproof boot won't fit, so you will have to make something up.
I had some Thin rubber sheeting and made a tube, inside it held the wiring  from led bulb to original bulb connector, so watch polarity and wire colours,but you can cut off the origin connector if you want, which will save space.
I hope this is your problem,  but I would still do some electrical troubleshooting.
http://www.banggood.com/18W-H4-6000K-White-1800LM-HiLo-Beam-LED-Motorcycle-Headlight-Lamp-p-971067.html
« Last Edit: June 18, 2016, 07:04:56 AM by xsel777 »
xsel777
Re: Stator Issue?
« Reply #6 on: June 18, 2016, 07:30:58 AM »
I did a quick search for agility 125 and came upon h4 as bulb type,  but now I see a possibility of h11 elsewhere,  so please check your manual,  or Google your bulb with Google pictures.
Vision
Re: Stator Issue?
« Reply #7 on: June 18, 2016, 04:34:06 PM »
"This is the direct link. H4."
FYI there's no link there.
I'm looking for a replacement bulb, not interested in installing new circuitry. Thanks though.
Vision
Re: Stator Issue?
« Reply #8 on: June 19, 2016, 01:01:17 AM »
I just had the bright burn out after about 5min of constant use.
If the stator was producing too much electricity wouldn't all the lights be burning out?
