Author Topic: belts  (Read 737 times)
belts
« on: June 17, 2016, 11:24:45 AM »
I found a place that sales all sizes of belts. you can match up to any belt you have. So with that said. Is it ok to go wider and shorter on a belt for maybe faster take off and better top end. Or is it longer belts that do the trick. I don't wana go so high up I hit the starter bendix eather.
TroutBum
  • 2012 Like 200i (sold)
Re: belts
« Reply #1 on: June 17, 2016, 05:17:31 PM »
When it comes to performance I heard it's best to stay with the recommended belt size and instead experiment with different weight rollers. Their are manufacturers that design variator/clutch kits with different specs than standard to optimize performance. But that's a match set all working within the parameters of your bike's optimum ability.
Mr. Paul
Re: belts
« Reply #2 on: June 17, 2016, 10:30:24 PM »
Stay with the stock OEM belt. You will not see any increase over stock with different sizes. Would almost certainly result in poorer performance. A wider belt for example, will not increase the "gear" ratio.  That is controlled by the size of your variator and rear  pulley. I agree with Troutbum, your best improvement can be made by fine tuning your variator weights to keep you in that RPM sweet spot in relation to your weight and road conditions. Good luck!
2009 Kymco People 150
1993 Honda Helix
RubenC
Re: belts
« Reply #3 on: June 17, 2016, 10:41:53 PM »
Please make sure that your pants don't fell down when your belt breaks.  Like mine almost did when my belt broke last week.
From the Great Nation called Texas. Oops I mean the Great State called Texas
paceneedsstides
Re: belts
« Reply #4 on: June 18, 2016, 06:29:06 PM »
if you wanted to change up at all go with a slightly longer belt this has been proven to allow more travel on both variator and rear driven pulley at top speed incresing it by a small amount but don't expect much and don't go much longer just a tad or belt could possibly slip off at top speed especially if you have certain tops of performance or oversized variators.
2013 Kymco/Malossi Like 70 2T
Malossi Dellorto 19mm Carb
94 main jet
Malossi Multivar
Dr Pulley 6gr Sliders
Malossi Torsion controller
Stage 6 Sport Pro Clutch
Stage 6 upgear kit
