Author Topic: OKO 21mm Carb  (Read 1412 times)
demeter
OKO 21mm Carb
« on: June 20, 2016, 04:30:04 AM »
Any ideas on how to mount an OKO 21mm carb to my Like?
I found this: http://pages.ebay.com/motors/link/?nav=item.view&id=200858549360&alt=web but the seller says it fits 28-32mm carbs. From my research the OKO 21mm is 35mm.. :/
2010 Like 50 2T (Malossi 70cc BBK, Tecnigas Next-R, Blue Polini Torque Spring, Yellow Clutch Springs, 5.5g Sliders, Stock Carb: 95 MJ, Stock Airbox Drilled, PIAA GT-X Headlight, Kolite 5630 Running Lights, 140/70-12 Rear Tire)
demeter
Re: OKO 21mm Carb
« Reply #1 on: July 07, 2016, 04:39:32 AM »
I guess I'll soak the rubber hose in hot water before install and grind a tiny bit of the lip off the carb.
 8)
