Author Topic: better mirrors (if you moved your turn signals)  (Read 767 times)
wheels
  • USA, NC, Raleigh
« on: June 22, 2016, 02:43:56 AM »
Years ago , I moved the turn signals to a 45lite LEDs in the fairing.   I did not like the mirrors, at times, you must lean back to see the mirrors.   When I installed the Biondi Windscreen, I mounted some Suzuki 600 mirrors directly to the windscreen ... looks better, improved rear vision field and you only need to move your eyes.
I found this Taiwan site the other day, I have not used them so cannot vouch for them.
They have mirrors with what appears to be a bracket that mounts to the windscreen bolts.
You would have to had moved your turn signals to the fairing to make use of these.
https://taiwanbigscootershop.com/products/t-b-s-s-kymco-dowmtown-moved-forward-mirror-systema1?variant=1022879961
2012  DT 300i  26K miles,  Bestem 929, Biondi w/s, LED brake/tail,turn, OEM mirrors fairing mount, removed buttstop
2015  GTi300  7K miles, Bestem 929 case, PUIG TS w/s, mirrors mounted to w/s, led DRLs in windguards
2014  Honda CTX700,  35Kmiles, many mods
MJR
Re: better mirrors (if you moved your turn signals)
« Reply #1 on: June 22, 2016, 06:36:02 AM »
I wish they had relocation brackets for the MyRoad 700i. I've bought a pair of Dimotiv brake levers from them on Ali Express, no issues there. I sent them some questions on Facebook but never got a response sadly as I wanted to buy some other things.
'03 Coast Cyan Atlantic 500
'14 White MyRoad 700i
'09 Mirage White Burgman 650
